help fitting tires
Discussion in 'Wheels & Tires' started by RyanBrooks7, Mar 4, 2013.
  1. Mar 4, 2013 at 6:11 PM
    RyanBrooks7
    RyanBrooks7 [OP] Member
    I got a set of 35's BFG on 17's. I want to put em on my taco. I have a 3inch suspension lift in the front and 2inch blocks in the back. I want to know if i add a 3inch body lift will the 35s' fit. will i have to cut? 2008 4x4. Thank you
  2. Mar 4, 2013 at 6:12 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Plenty of guys on here running 35s with 3" lifts. It looks great but you will have to trim!!
  3. Mar 4, 2013 at 6:13 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Fuck the body lift.
    Fuck the blocks.
    Put a real 3" suspension lift on and enjoy.
  4. Mar 4, 2013 at 6:13 PM
    ColtsTRD
    Scott
    AZ
  5. Mar 4, 2013 at 6:14 PM
    ColtsTRD
    Scott
    AZ
    Agreed
  6. Mar 4, 2013 at 6:45 PM
    RyanBrooks7
    I would like to avoid cutting. would they fit with 3inch sl and a 3inch bl? 35x12.5x17
  7. Mar 4, 2013 at 7:15 PM
    Spoonman
    Jamie
    Alberta
    The rear will clear with 3" suspension. Front is more tricky. You will still rub fender flares in front, and your cab mount with a total of 6".
  8. Mar 4, 2013 at 7:15 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    If you want to avoid cutting, you will need to pick a different size tire.
  9. Mar 4, 2013 at 9:05 PM
    Spoonman
    Jamie
    Alberta
    That's the truth right there. If you don't want to rub, stay stock
  10. Mar 4, 2013 at 9:23 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Why on earth would you be willing to put on a body lift but be unwilling to do a little cutting that anyone who's unfamiliar with lifted Tacomas won't even be able to notice?? :confused::confused:
  11. Mar 4, 2013 at 9:27 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Also - folks aren't deliberately avoiding answering your question literally. 3" body lift stacked on 3" suspension lift is a fairly unusual combination around here, so very few folks actually know for sure what level of wheelwell trimming (if any) is required.
  12. Mar 5, 2013 at 10:10 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    One other thought for you -
    A common tire interference point is the "cab mount" which is permanently welded to the frame. (Some folks would say it's part of the frame.)
    At any rate, the cab mount does NOT move when a body lift is applied. So if your 35x12.5" tires rub the cab mount on a 3" lift (likely) they'll continue to do so after putting on a body lift, unless you cut it. (see "cab mount chop")
  13. Mar 5, 2013 at 11:17 AM
    RyanBrooks7
    if i stay with just the 3inch suspension lift, would there be a lot of cutting other than the cab mount??
  14. Mar 5, 2013 at 11:19 AM
    Large
    Large Red
    Cutting, smashing, beating, welding? Yes
  15. Mar 5, 2013 at 11:19 AM
    Large
    Large Red
    Or you could just get glass on top of your lift
  16. Mar 5, 2013 at 11:21 AM
    la0d0g
    la0d0g Its 4 oÂ’clock somewhere
    running for the hills
    For crawling not hauling
    You should just go with a 6" db and call it a day :anonymous::D
  17. Mar 5, 2013 at 11:31 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    You'll need to chop the cab mount, a 3 inch body lift will not get around that. Either 6 inch drop bracket, or 3 inch with a good amount of trimming will be required.
  18. Mar 5, 2013 at 11:39 AM
    TicoTRD
    TicoTRD Well-Known Member
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    so for 33s will you need a 3in lift or can u just keep the stock suspension?
  19. Mar 5, 2013 at 11:43 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    If you lift 3 inches, you wont need to trim as much as you would for stock suspension.
  20. Mar 5, 2013 at 11:52 AM
    TicoTRD
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    so even with a 3in lift and 33s u will stiil need to do some trimming? and with a 3in lift wont you have to get upgraded uca's?
