help! flare nut on brake lines.. whats wronge?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kinkrider101, Jan 29, 2012.
  1. Jan 29, 2012 at 11:07 AM
    kinkrider101
    kinkrider101 [OP] Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    The flaren ot on the bottom of the front brake line will unscrew half way, then you turn it one more and it popes up...then back down, so I can't screw the flare nut out, but I can still tighten it back up.
  2. Jan 29, 2012 at 11:11 AM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Are you using flare nut wrenches? I'm not sure I understand what you are talking about.
  3. Jan 29, 2012 at 11:14 AM
    jandrews
    '09 FourDubDee TRD OR
    Common issue...flare nuts were overtorqued from factory...basically need to be replaced...sucks...
  4. Jan 29, 2012 at 11:15 AM
    kinkrider101
    santa barbara
    wheels and tires
    Yes I was using a flare wrench, it unscrewws half way but won't unscrew anymore, can I use the rubber hose on one side and ss on the other?
