HELP!!!! fog light install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mwojo225, Mar 13, 2022.
  1. Mar 13, 2022 at 1:05 PM
    mwojo225
    mwojo225 [OP] New Member
    Hey everyone. I new here. I recently bought a 2022 Taco SR5. I have installed fog lights on my truck. however i can get them to work. I followed Nitori's install for them. I have the pre-wire method. I changed out the headlight stack swap. Everything is connected correctly. However i cannot get the lights to come on. Any help would be appreciated.
  2. Mar 13, 2022 at 1:43 PM
    r_ben65
    r_ben65 Well-Known Member
    Robert
    2023 TRD Off-Road Lunar Rock
    Exhaust reroute, cargo mat, WeatherTech side window deflectors, glove box and center console organizer. RCI steel skid plates (engine, transmission, transfer-case, catalytic guards, fuel tank and differential), Total Chaos Bed Stiffeners, RCI rocksliders, Power Tray and Switch Pro, Taco Vinyl Pro Grill, Diode Dynamics SS3 amber fog lights. Front Runner load bars, Powerbrake D-Line Disc & Pad kit, Fox 2 inch lift kit with 2.5 coil-over, Taruca Rogue 270 degree XC awning, Four Wheel Campers Project M, CBI Baja Front Bumper, Warn VR EVO 10S winch, Baja Design OnX6+ 20 inch LED Light Bar, WeBoost
    My SR was pre-wired and I swapped out the stalk switch. Mine will only work when the parking or headlights are on. If all lights are off or just using the DRL, the fog lights won't work. Not saying you didn't try that but it took me a minute to figure that out. Hoping that's the issue.
  3. Mar 13, 2022 at 5:32 PM
    sagia12
    sagia12 New Member
    larry
    2017 SR Access cab
    None
    Today, I also changed out the stalk on my 2017 SR5. The fog lights only work if the parking or headlights are on (it took me awhile to figure that out). No DRL lights when the stalk is in the DRL position.
  4. Mar 13, 2022 at 6:28 PM
    r_ben65
    Robert
    So the fog lights are working like mine do but your DRL isn't working. Assuming the DRL's were working before you swapped out the stalk switch, I'm wondering if when you connected the new stalk switch if you messed up the wiring connection of the wires that control the DRL. Maybe take a look at that and check the connection. Possibly pulled on a wire a little too much and the connection is bad.
  5. Mar 14, 2022 at 6:04 AM
    sagia12
    sagia12 New Member
    larry
    2017 SR Access cab
    None
    Thanks for the suggestions. I can check the connections. I'm leaning towards - maybe that the new stalk thinks that I have the LED DRLs rather than the orange bulb DRLs (different wire to headlight combination?). I have been unable to find the DRL wiring diagram. As for the fog lights only working with the headlights on, is not what I want, although apparently that is what Toyota wants. There are some YouTube videos, hacking the relay and connecting it to a switch, but after all the work installing the stalk that is going back to what I previously had.
  6. Mar 14, 2022 at 6:13 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    Fogs only working with low beam is DOT compliant operation
