Help! Found puddle of water on floor mat
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KrnTaco08, May 19, 2019.
  1. May 20, 2019 at 9:12 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Probably too late now but if it happens again and you didn’t find the leak, check the passenger side seat belts - pull them all the way out to see if they’re wet.
  2. May 20, 2019 at 9:17 AM
    KrnTaco08
    KrnTaco08 [OP] Well-Known Member
    LA
    2017 Taco
    Ok. What would that determine? Leakage on the B-pillar?
  3. May 20, 2019 at 9:18 AM
    OnHartung'sRoad
    Yeah, but since you didn’t do a roof rack it probably will be dry. If it was the rear brake light, your headliner would be wet in the middle towards the seats in the back. Good to check anyway in case that windshield leak is not found.
  4. May 20, 2019 at 9:24 AM
    KrnTaco08
    LA
    2017 Taco
    Sounds good. I’ll double check the rear again. I’m thinking about going to a self car wash and try to replicate the problem by spraying my truck down? Bad idea?
  5. May 20, 2019 at 9:32 AM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    Also check cabin air filter area and look down into the blower motor/squirrel cage fan area for any water. If water came in through the cabin air intake, that's where it would go and it would end up on top of the floor mat below the blower motor.
    CusterFan and OnHartung'sRoad like this.
  6. May 20, 2019 at 9:35 AM
    OnHartung'sRoad
    Not sure... there are some good suggestions being offered here to try first.
    KrnTaco08[QUOTED][OP] likes this.
  7. May 20, 2019 at 9:40 AM
    bradshawnh
    bradshawnh ...to the rescue!
    Boston, MA
    2017 TRD OR DCSB 6MT, Tech, Inferno
    I had this happen to me many times during a hard rain.
    The water runs down the window and drips inside the door. Depending on the angle you park at, the water hits the back of the speaker and drips down onto the door panel, and out onto the floor mat.
    KrnTaco08[OP] likes this.
  8. May 20, 2019 at 9:47 AM
    Clearwater Bill
    Billy
    Largo Florida
    Use a 2nd person and very bright light on a pitch black night. That will reveal things that are 'direct path'.
  9. May 20, 2019 at 10:30 AM
    KrnTaco08
    LA
    2017 Taco
    Interesting. The small puddle that I found on the rubber floor mat was closest to the door. It wasn’t all over the floor mat either. Just a small puddle.
  10. May 20, 2019 at 10:32 AM
    KrnTaco08
    LA
    2017 Taco
    That’s a good idea. I flashed my light under the glove compartment area and didn’t see any sign of water run off, etc.
  11. May 20, 2019 at 10:55 AM
    Boosted_Carrera
    Boosted_Carrera Well-Known Member
    Hawaii
    2018 TRD SPORT, 1996 911 Turbo
    Have someone run water over the truck and look for and leaks. Or when you wash the truck with a sprayer . Sit inside and hopefully you can catch a drip. If all fails, you have warranty.
  12. May 20, 2019 at 9:22 PM
    KrnTaco08
    LA
    2017 Taco
    So I Went to a self car wash today. I sprayed the truck down for about 10-15 mins. Checked the floor mats and there was no puddle.
    I checked about every hour and no puddle. :notsure:
