Help! Front fender holes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wpperry83, Apr 25, 2024.
  1. Apr 25, 2024 at 1:12 PM
    Wpperry83
    Wpperry83 [OP] Member
    07 Tacoma
    So I recently purchased an aftermarket front fender, hand it painted and noticed there was NO HOLES for the fender flare. Basically look for any advice/help for making these holes so that I can mount it.
  2. Apr 25, 2024 at 1:14 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Post a picture of the truck and the flares
  3. Apr 25, 2024 at 1:20 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    Buy a set of aftermarket flares that mount with 3M tape. Try to mount the old one with 3M tape. Or mark the the fender where the flair covers, mark the hole locations. Cover with masking tape. Measure again, use a center punch to mark them all and a new bit to drill them out. Pull the tape, touch up the bare metal and mount. If it's the punched square holes like the 2nd gen had for the clips I would say you are screwed.
    If you drill into the painted fender cover it with masking tape first. This should keep the paint from cracking or chipping. Go slow.
  4. Apr 25, 2024 at 1:23 PM
    Wpperry83
    07 Tacoma
    It’s a 2nd gen with the square holes I’m pretty sure.
    JJ Customs likes this.
  5. Apr 25, 2024 at 1:25 PM
    JJ Customs
    Jay
    NV
    I mean, you could do it with a Dremel or something I am sure. Just buy a set of whole new flares. The bushwackers don't even use those holes. Just coverers them up. Most any aftermarket flares don't use those holes.
  6. Apr 25, 2024 at 1:32 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    If you got a fender with no holes, you got a 2wd fender. Its the same, but they didnt come with flares. Best bet is to return it and get one meant for a 4wd truck. Or get a matching fender for the other side
    JMcFly likes this.
  7. Apr 25, 2024 at 1:32 PM
    Wpperry83
    07 Tacoma
    Not really into the aftermarket flares. Gonna give this a go this weekend and see what happens! Thanks for the feed back
  8. Apr 25, 2024 at 1:34 PM
    OffroadAlliance.com
    OffroadAlliance.com Well-Known Member Vendor
    Brockton, MA
    2018 Tacoma TRD Pro
    you going to dremel it out to fit flares?
  9. Apr 25, 2024 at 1:40 PM
    JJ Customs
    Jay
    NV
    Good luck. If you have the old fender mask it off and mark where it lines up. Mark the holes then transfer that to the new fender. Drill the corners of the box then use a Dremel with a little cutoff wheel to connect the dots and square off the corners and you will get it done. The trick is masking off the entire area and marking, cutting through that. It will all be covered but take your time and you will get it.
    SH10151 likes this.
  10. Apr 25, 2024 at 1:42 PM
    Wpperry83
    07 Tacoma
    yup this is the plan! I will post pics of the process once it’s done and I figure out how to lol
  11. Apr 25, 2024 at 2:01 PM
    JJ Customs
    Jay
    NV
    Make sure you drill the corners of your box then use the cutoff to connect those. If you take your time it will come out fine. Make sure they are dead nuts in the right spot before you cut them but if you have the old fender that should be easy. Stack some tape and mark the wheel arch. Line that up and stick it to the new fender then all you have to do it the rest. You will get it. I would use the old fender to make a couple boxes to learn before I cut into the new one also. Tools required:
    - Dremel with the small cut-off wheel attachment.
    - Center punch so the bit does not walk (preferably a spring loaded one)
    - Drill, several small bits. Like 1/8 inch
    - Good automotive masking tape. Not that blue shit from home depot for painting
    Wpperry83[OP] likes this.
  12. Apr 25, 2024 at 2:23 PM
    Wpperry83
    07 Tacoma
    appreciate all the feedback brother. This was exactly what I was thinking right here! Fingers crossed! I’ll keep you updated
    JJ Customs[QUOTED] likes this.
