Help: Fuel pump won't prime
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nismooo, Jan 6, 2018.
  1. Jan 6, 2018 at 9:59 AM
    nismooo
    nismooo [OP] Active Member
    Tacoma
    lift and tires
    So I have been having this problem with the truck that it won't start only when its cold it seems like (under 15 degrees). I tracked it down to the fuel pump not priming. I did not hear it outside the tank and I popped the cap off and still did not hear a sound. Next I went to the fuse box. The EFI fuse is good, EFI relay clicks. Fuel pump relay DOES NOT click. So I took the relay out and went inside and checked it with a battery and it does click when I hook it up to a 12V battery. Now this is where I am stuck. I wouldn't the Fuel pump relay click in the car but does outside when I connect it to a battery?
  2. Jan 6, 2018 at 11:39 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Because for some reason the ECU is not commanding the relay to energize. there is nothing wrong with the relay.
    I would guess that you have the engine immobilizer that is not reading the chipped key.
  3. Jan 6, 2018 at 11:51 AM
    nismooo
    Tacoma
    lift and tires
    Its gotta be this remote starter. I had this thing installed like two weeks ago and it has been giving me issues. They keep trying to things to fix it and it came to the point where i thought Maybe it was something with my car? Im gonna have to ask for my money back. They can't get it to work right.
  4. Jan 6, 2018 at 12:29 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Once again (apparently), aftermarket accessories - all too often poorly installed - cause an issue. So sad. And I hate to piss on your parade, but you may have another issue even if the shop that installed it removes it. All too often I've seen "professional installers" spice into wiring harnesses by slicing a piece of insulation off the wire they want to splice into with a pocket knife, then striping and wrapping the end of the wire they want to splice in around that exposed section. Sometimes they even wrap a small piece of electrical tape around the mess to "insulate it." By the time I usually find this kind of hack work, I'm in no mood to deal with it. I hope this didn't happen to you because you have no idea how bad some of the stuff I've seen truly is.
    So if you elect to have the shop in-install it, you might want to check their work - before and after - to make sure you don't have any problems down the road.
  5. Jan 6, 2018 at 5:35 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    I don't think Yota fuel pumps get power until the engine cranks unlike most US manufacturers which power it up as soon as the key is turned to the run position. Your issue will very likely be due to the shop that installed the remote starter, they spliced into the wire that powers up the FP relay and it no longer can shunt power to it. No FP relay closing, no power to the fuel pump.
  6. Jan 6, 2018 at 8:08 PM
    nismooo
    Tacoma
    lift and tires
    Thanks guys. Im gonna have them take it out. And ill double check afterwards.
  7. Jan 6, 2018 at 9:53 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Damn, makes you second guess the remote starter, huh....
