HELP. fuse gone bad?
Discussion in 'Lighting' started by zeecue, May 26, 2012.
  1. May 26, 2012 at 7:17 AM
    zeecue
    zeecue [OP] Active Member
    Zac
    Arkansas
    12 PreRunner SR5
    Tinted Windows
    hey guys, i tried installing an LED dome light in my truck and after taking it out a few times (put the wrong side in first) none of my interior truck lights work (dome light, map lights, clock resets after ignition is turned off/on) -- any idea what is going on here? i'm guessing it's a fuse gone bad. i tried getting in contact with my Toyota dealership service department but they are closed on Saturdays :(
  2. May 26, 2012 at 7:18 AM
    98tacoma27
    Ben
    Not Beech Creek
    Sounds like you blew a fuse
  3. May 26, 2012 at 7:19 AM
    zeecue
    Zac
    Arkansas
    12 PreRunner SR5
    Tinted Windows
    any idea where and which one it'd be? i took the coin tray out to check that fuse panel but i don't think it'd be located in there?
  4. May 26, 2012 at 8:16 AM
    98tacoma27
    Ben
    Not Beech Creek
    It's on the left side under the dash (by the left kick panel).
  5. May 26, 2012 at 8:18 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    what he said... ;)
  6. May 26, 2012 at 8:21 AM
    zeecue
    Zac
    Arkansas
    12 PreRunner SR5
    Tinted Windows
    like behind the coin tray or down by the brake? how in the heck do i get down there to check those out?! :facepalm:
  7. May 26, 2012 at 9:50 AM
    zeecue
    Zac
    Arkansas
    12 PreRunner SR5
    Tinted Windows
    hey guys, i was putting in an LED dome light and after removing it a few different times (not a good contact) apparently i have blown a fuse..now my dome light and map lights do not work and my clock resets the time after turning the ignition on/off -- has anyone else ran into this problem? a few guys from another thread have told me the fuse is located in the bottom left kick panel, but i'm wondering if anyone knows exactly which one could be blown? (it's hard enough to get down there to check) :confused:
  8. May 26, 2012 at 9:51 AM
    zeecue
    Zac
    Arkansas
    12 PreRunner SR5
    Tinted Windows
    MOD PLEASE DELETE THREAD -- POSTED IN ANOTHER FORUM, THANK YOU!
  9. May 26, 2012 at 9:58 AM
    98tacoma27
    Ben
    Not Beech Creek
    No need for duplicate threads. It could one of a couple fuses. You have to pull them to check. I'd start with the dome fuse.
