Help! Fuse problem??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomud987, May 25, 2010.
  1. May 25, 2010 at 6:24 PM
    tacomud987
    tacomud987 [OP] Active Member
    NC
    Black 2007 Access Cab
    bull bar, hella 500 lights, black low profile toolbox, JVC touch screen radio, dick cepek DC 1 black rims and 33inch Nitto Terra Grapplers, 12 in JL w3 sub w/ alpine amp, haha locking gas cap for those morons who think they can steal from people who actually pay for their gas, cb radio w/ P.A. speaker, Pro Comp leveling kit and a Pro Comp add-a-leaf to give me a little lift until i save for a 6in
    I have an 07' Access Cab and today i was messing with my trailer adapter and it sparked and im quite sure i blew a fuse because.... i got shifter to lock up the shifter indication lights on the dash wnt come on, my passenger seatbelt warning is on my turn signals dnt work and my a/c button doesnt work PLEASE HELP im sure its something dumb and this has happened before but the dealership never told exactly where they fixed it and charged me damn $83 bucks to fix it all they said was that there were two fuses messed up So please any help ASAP is apprecitated
  2. May 25, 2010 at 6:25 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Well did you check all your fuses? Thats probably the problem.:cool:
  3. May 25, 2010 at 6:31 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    take a good small flashlight and start checking all the fuses
    If it took out all of that, it should be easy to see which one is blown.
    look for the one with the metal strip inside that has melted, may look burnt
  4. May 25, 2010 at 6:31 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    Use this PDF for assistance. I would not do this again if I were you. Whenever you work on electrical shit, unhook the negative cable from the battery.
  5. May 25, 2010 at 6:32 PM
    tacomud987
    NC
    Ive checked every fuse in the fuse box in the engine compartment and in the cab everything seems to be good. Im missing something obviously dangit.
  6. May 25, 2010 at 6:34 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    A fuse is, without any doubt, blown.
    The fact that you have to pay a dealer $83 to replace two fuses that cost about $2.50 for a pack of 5 really frightens me, in the sense that I don't actually know if any advice I could give you would be helpful-
    BUT, you need to turn your truck OFF, access your fuse panel in both the cab and under the hood and start inspecting. You have to use the fuse puller that should come attached to the plastic cover of the fuse panel and pull each individual fuse out, one by one, and inspect them. the small sliver of metal should be connected through the entire body of the fuse.
    I will pray for you.
    :D
  7. May 25, 2010 at 6:51 PM
    tacomud987
    NC
    Haha i used a test light and got nothing i'm gonna have to go old fashion and check by hand every dang one... but my question is.. its not one of the larger fuses or something of that nature is it?
  8. May 25, 2010 at 6:52 PM
    wlmuncy
    William
    Knoxville, TN
    You will need to check them all including looking at the relay's to make sure none looked scorched.
  9. May 25, 2010 at 6:53 PM
    tacomud987
    NC
    im new to electronics i know a little bit but not much im 18 and learning please explain what you mean by checking those relays in the fuse box how do i? sorry for my ignorance
  10. May 25, 2010 at 6:55 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    IGN No.2 and TAIL fuse. That's what my $ is on.
    :popcorn:
  11. May 25, 2010 at 6:59 PM
    wlmuncy
    William
    Knoxville, TN
    The relays and more fuses are located in the relay box inside the engine compartment. That PDF I attached will show you the location. Check those fuses first. If all are good, you can pull the relays. A scorched relay will have black marks.
    Here is a picture. Not the best, but should give you an idea.
    http://www.askamechanic.info/askamech2/images/random images/Scorched.jpg
  12. May 25, 2010 at 7:00 PM
    tacomud987
    NC
    IGN no. 2 is ok i just check it and so is TAIL
  13. May 25, 2010 at 7:04 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Damn........keep checking the others!
  14. May 25, 2010 at 7:07 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    IGN1 failure causes the shifter to lock up. I'd start there personally.
  15. May 25, 2010 at 7:10 PM
    tacomud987
    NC
    Turns out i found at least one it was the IG1 maybe more? i havnt gotten to replace it yet but i really appreciate you help guys this site has saved my tail more times than i can count. Lets hope it was just this one fuse. Do you think it might be one more?
  16. May 25, 2010 at 7:13 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Could be but ya won't know till ya check 'em all.
  17. May 25, 2010 at 7:17 PM
    tacomud987
    NC
    yea i hear ya thanks guys your all life savers haha
  18. May 25, 2010 at 7:27 PM
    lezavw90
    lezavw90 Active Member
    I had a similar problem. When i hooked up my trailer and took it out of park the fuse would blow. Turns out the back up lights on my trailer were grounded.
