Help! Getting bottom of shock to line up with bracket on lca
Discussion in 'Suspension' started by larrybugcatcher, Mar 29, 2015.
  1. Mar 29, 2015 at 9:00 AM
    larrybugcatcher
    larrybugcatcher [OP] Well-Known Member
    Tristan
    NC
    03 Xtracab 4x4 & 20 DCSB 4x4 stock
    3" Toytec Boss coilovers and Toytec AAL 33x10.50s KO2
    Yes, my dad is pushing it all the way down with a large pry bar. We still can't get it lined up
  2. Mar 29, 2015 at 9:02 AM
    larrybugcatcher
    Tristan
    NC
    It won't disconnect without removing the sway bar, correct? We've used a impact gun and it won't budge.
  3. Mar 29, 2015 at 9:06 AM
    scocar
    scocar Patron of the Farts
    That's my experience. Do you have an angle grinder? If that swaybar link's bolts are fubar, try to cut the lower link bolt off with the angle grinder. Or failing that, just cut the link in half and replace it later if you want to. You can remove the whole sway bar later to work on R&Ring the link hardware.
    You can get new one for $20-30.
    http://www.partsgeek.com/gbproducts...+Google+Base&gclid=CPzppo34zcQCFYeTfgodLVkA7A
    If the one on the other side is less f'd up, you can disconnect that one and it should help.
  4. Mar 29, 2015 at 9:11 AM
    larrybugcatcher
    Tristan
    NC
    Yeah, I have an grinder but I'm pretty gunshy about cutting it out. I've been working on this for hours so in going eat some lunch and then see if I can get it loose.
  5. Mar 29, 2015 at 9:15 AM
    scocar
    You wont' hurt anything, seriously. My sway bar is hanging in my garage rafters after I installed my OME suspension, and like I said, you can get those parts pretty cheap and easy.
    Good idea to take a break. There is another trick us use an upside-down hydraulic bottle jack inside the wheel well (at a strong area) and pushing down on the upper control arm at the top nut of the spindle. I am looking for pics now.
  6. Mar 29, 2015 at 9:22 AM
    larrybugcatcher
    Tristan
    NC
    Right on. Would I have to buy the end links online or is it something I could get at a chain parts store?
  7. Mar 29, 2015 at 9:23 AM
    Large
    Large Red
    Just take the sway bar off, hang it on the wall like a trophy. If you really want it back on I'm sure you could ask for another member's sway bar .. they are laying around everywhere
  8. Mar 29, 2015 at 9:23 AM
    Large
    Large Red
    You can buy end links online, scocar gave you link you even quoted above :D
  9. Mar 29, 2015 at 9:27 AM
    larrybugcatcher
    Tristan
    NC
    Yeah, I've read a lot of people taking the bar off but I was hoping if I decided to cut the links in half I could put them back today if I wanted to.
  10. Mar 29, 2015 at 9:27 AM
    scocar
    Bottle jack trick.
    http://www.bajataco.com/saw-bottlejack.jpg
    But you may still need to cut the links. End links:
    Edit: just be careful as you push down with the bottle jack that it doesn't force the coil spring into the end of upper control arm. Keep an eye on that.
  11. Mar 29, 2015 at 9:49 AM
    larrybugcatcher
    Tristan
    NC
    Well I'm about to go at it again. I'm going to try the bottle Jack trick first, then see if I can loosen the sway bar nut
  12. Mar 29, 2015 at 10:02 AM
    larrybugcatcher
    Tristan
    NC
    ImageUploadedByTapatalk1427648491.584845.jpgImageUploadedByTapatalk1427648504.973690.jpg
    Okay so this is it as far as it goes. Just barely not enough! Going to try on the nut now
  13. Mar 29, 2015 at 10:05 AM
    scocar
    One last thought. Do you have the entire front end of the truck in the air, i.e., the passenger wheel is not on the ground, correct? That would fight against you on the driver side.
  14. Mar 29, 2015 at 10:06 AM
    larrybugcatcher
    Tristan
    NC
    Yeah. I'm actually working on the passenger side, but the truck is in the air with both wheels off
  15. Mar 29, 2015 at 10:16 AM
    #35
    larrybugcatcher
    Tristan
    NC
    A small victory has come my way!!!!!
  16. Mar 29, 2015 at 10:18 AM
    #36
    larrybugcatcher
    Tristan
    NC
    Now that I have the sway bar disconnected, how do I go about getting the lca loose from the joint?
  17. Mar 29, 2015 at 10:24 AM
    #37
    Large
    Large Red
  18. Mar 29, 2015 at 10:28 AM
    #38
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Got a small scissor jack in any of your vehicles?
    Insert it between the bumpstop on your LCA and the bump pad on the frame. Carefully crank it to force the LCA down some more.
  19. Mar 29, 2015 at 10:43 AM
    #39
    larrybugcatcher
    Tristan
    NC
    I don't have a scissor Jack unfortunately. Kinda scared to start disconnecting this stuff.
  20. Mar 29, 2015 at 10:55 AM
    #40
    scocar
    Nice.
    You should NOT need to, I don't think. Use the bottle jack again to push down on UCA again.
    edit: I meant to say NOT
