Help getting Timing chain cover off
Discussion in '1st Gen. Tacomas (1995-2004)' started by cresentfresh, Jul 4, 2025.
  1. Jul 4, 2025 at 6:21 PM
    cresentfresh
    cresentfresh [OP] Member
    Oregon
    '99 2wd tacoma sr5
    K&N drop in filter and 1 inch lowering blocks
    Finally stated working on replacing my timing chain on my 1999 2wd 2rz with 280k. I've got all the bolts out including the two bolts that run down inside the valve cover. I just can't get it to budge. Any tips? Is there pry point areas that are safe
  2. Jul 4, 2025 at 6:48 PM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    Did you drop the oil pan out too and remove the stuff down there? Got any pictures of it?
  3. Jul 4, 2025 at 7:27 PM
    cresentfresh
    Oregon
    '99 2wd tacoma sr5
    I did remove the oil pan and removed the pick up tube. Im thinking it's just stuck on from never being removed before. Two of the cover bolts were actually missing
  4. Jul 5, 2025 at 5:15 AM
    noodles93
    Charleston, SC
    On my 3rz getting the cover off was a pain as well. Once all the bolts were removed I started hammering in plastic wedges along the timing cover/block. It eventually broke free.
  5. Jul 5, 2025 at 9:23 AM
    cresentfresh
    Oregon
    '99 2wd tacoma sr5
    I'll gave the tappy tap a shot. I tripled checked for all the bolts again just to make sure I didn't miss something. Being on there so tight I'm concerned about tearing the head gasket
  6. Jul 5, 2025 at 9:25 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW…
  7. Jul 5, 2025 at 9:28 AM
    cresentfresh
    Oregon
    '99 2wd tacoma sr5
    Thank you. Always had some type of toyota since 1996. Dad had a '94 pickup and I picked up this '99 8yrs ago with 220k on it. Just now starting to show a few issues. Used to working on 90's honda's. Judging by your name you seem to know them well :p
  8. Jul 5, 2025 at 9:30 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    If its siliconed on, I always get a prybar in there & carefully pry the cover loose while not bending anything...
    maybe place prybar between cam gear & TC...
    or corner of head & TC,
    I have no idea what it looks like...
    but you need to break the adhesion seal of the silicone if its what seals the entire cover, theyre glued on really good....
  9. Jul 5, 2025 at 9:32 AM
    noodles93
    Charleston, SC
    So when I tapped my timing cover off it did take a little bit of the headgasket with it. Wasn't any problem, been 3 years and its still fine.
  10. Jul 5, 2025 at 10:44 AM
    cresentfresh
    Oregon
    '99 2wd tacoma sr5
    I got her off guys. Pry method worked just when I was about ready to give up I gave it one more good UGGA then she cracked off. Thanks guys.
    joeyv141 and ControlCar like this.
  11. Jul 5, 2025 at 10:57 AM
    slater
    San Diego
    :thumbsup:
  12. Jul 5, 2025 at 5:51 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Congrats!!!!
    BIG job.
    Took me 4 days of slow methodical work
  13. Jul 5, 2025 at 7:58 PM
    cresentfresh
    Oregon
    '99 2wd tacoma sr5
    Ya I installed the LCE engineering timing belt kit along with water pump. Still need to button up a few things and order a gasket for the bypass water joint
