[HELP] - going up tire sizes!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scoobarooo, Dec 27, 2015.
  1. Dec 27, 2015 at 9:52 AM
    Scoobarooo
    Scoobarooo [OP] Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    im ordering tires tomorrow. I have 265/70/16 on my truck now.
    I want to go up one size.
    Stock truck other than a 1.25 level in the front end.
    Will I rub?
  2. Dec 27, 2015 at 9:59 AM
    JeffP213
    JeffP213 I used to do mods. I still do, but I used to, too
    Jeff
    Central, VA
    15 TRD OR
    Going up to a 285? With a 1.25" leveling kit? They won't rub, because they won't fit. There's about a thousand threads on this forum about this same question.
    Crock112 likes this.
  3. Dec 27, 2015 at 11:22 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Seems alot of people dont understand that you dont clear tires with a standard 3" lift. The ride height is raised but the travel is still the same (unless your running spacers). 33s will and have fit with no lift at all by doing minor triming and pinch weld mod (12.5 wides will need more backspacing and a little more trimming because of it.)
  4. Dec 27, 2015 at 11:27 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Not sure what you mean by one tire size. You could put 265/75r16 tires on, those are about 32" diameter. You will rub a little, but trim the fender liner a bit on the spots that rub and you'll be good. I wouldn't go up to 285/75r16 until you're ready to do some pinch weld bashing and whatnot.
  5. Dec 27, 2015 at 12:45 PM
    JeffP213
    Jeff
    Central, VA
    15 TRD OR
    There is no amount of trimming or or pinch weld modifications I could have done to have gotten my 33's to fit under my truck prior to the lift
  6. Dec 27, 2015 at 1:40 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Was that for 1st gens or your 2015?
  7. Dec 27, 2015 at 2:22 PM
    JeffP213
    Jeff
    Central, VA
    15 TRD OR
    2nd Gen. Can you get 33s under a 1st gen? I know there used to be a lot more room in the fender in my '94 pickup
  8. Dec 27, 2015 at 2:23 PM
    JeffP213
    Jeff
    Central, VA
    15 TRD OR
    I honestly just wouldn't want 33s (well at least 285s) under a stock suspension, if nothing else for cosmetic reasons. Just wouldn't look proportional imo
  9. Dec 27, 2015 at 2:29 PM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    Put them on and find out for yourself
    INSEIN likes this.
  10. Dec 27, 2015 at 8:47 PM
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Well I'm talking about 265/75/16. I don't wanna go wider. It would only add half an inch. I'm just talking about going taller.
  11. Dec 29, 2015 at 9:01 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    No issues with my 265/75/16s rubbing, suspension is stock springs with front 5100s set at 1.85 to level the truck.
