Help! Goodyear left my lower control arms loose
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PJTACO, Jun 14, 2019.
  1. Jun 14, 2019 at 8:00 AM
    PJTACO
    PJTACO [OP] Well-Known Member
    2017 Cement TRD PRO
    Hey guys I need some help. I went to Toyota yesterday for a "clack" noise whenever i compressed the suspension. They told me that my lower control arm alignment bolts were a full turn loose and the cams were upside down.
    Additionally, my tires were chunking up because of it.
    They said they tightened everything up, and I should take it back to Goodyear to fix what they broke, and that it's possible that the holes in the LCA are hollowed out from it being able to move.
    The clack noise is still there. I'm at Goodyear and they are denying that the tire wear is from them, because there were some missing wheel weights.
    They also told me that the truck was almost perfectly aligned, however their "before and after" spec sheets were printed 4 minutes apart.
    Is this not impossible? I've been driving for thousands of miles with loose lca bolts. Think they're lying to me?
  2. Jun 14, 2019 at 8:08 AM
    Minimag95
    Minimag95 Well-Known Member
    Niles
    Annapolis, MD
    2009 Pyrite Mica V6 SR5 4x4
    OME's w/ 887 Coils, SPC UCA's, 285 ST Maxx. Mobtown sliders & skid
    Did you notice steering issues that could have been related to a poor alignment?
  3. Jun 14, 2019 at 8:09 AM
    Freetime
    Freetime Well-Known Member
    2016 TRD OR AC 4x4 Quicksand
    You've waited way too long to be able to pin this on them.
  4. Jun 14, 2019 at 8:11 AM
    PJTACO
    2017 Cement TRD PRO
    Yes, I noticed it starting to degrade a bit after a while, and the steering wheel was shaking at 60 mph
  5. Jun 14, 2019 at 8:11 AM
    PJTACO
    2017 Cement TRD PRO
    Why? This was only a couple of months ago
  6. Jun 14, 2019 at 8:14 AM
    Minimag95
    Niles
    Annapolis, MD
    I had a (kinda) similar issue recently. Went to Mr. Tire for an alignment, was charged $160 for an exotic alignment. The tech ended up bending my alignment tabs down because my cam bolts were seized up. Went back to Mr. Tire and demanded a refund for the "alignment". Ended up getting together with another TW member and we repaired it ourselves. If I were you I definitely wouldn't trust Goodyear to make any "repairs". Most you can do at this point is try to get a refund from Goodyear and take the hit for the additional parts (and labor if you don't feel comfortable doing it yourself)
  7. Jun 14, 2019 at 8:17 AM
    Minimag95
    Niles
    Annapolis, MD
    When you say, "it's possible that the holes in the LCA are hollowed out from it being able to move", what exactly are you referring to?
  8. Jun 14, 2019 at 8:19 AM
    Clearwater Bill
    Billy
    Largo Florida
    :eek:
    Wallowed out would be more accurate. But while possible, fairly unlikely.
    Yep.
    Time isn't the big issue. Thousands of miles is.
    tonered likes this.
  9. Jun 14, 2019 at 8:21 AM
    PJTACO
    2017 Cement TRD PRO
    Essentially, if the bolt isnt tight, it can allow relative movement between the bolt and the hole wearing it out as vibrations and bumps travel through the parts, I assume.
  10. Jun 14, 2019 at 8:30 AM
    Minimag95
    Niles
    Annapolis, MD
    Hmm, i'd be surprised if that were the case. Those sleeves are galvanized hardened steel I couldn't see a couple months of friction wearing them out that badly. I'm assuming the clunk that youre hearing is the lower control arm moving in the slot on the LCA mounting brackets?
  11. Jun 14, 2019 at 8:31 AM
    PJTACO
    2017 Cement TRD PRO
    I thought so, but even after they're tightened down, I'm getting the same "clack" under hard, quick suspension compressions like slamming the brakes or hitting a driveway entrance
  12. Jun 14, 2019 at 8:33 AM
    PJTACO
    2017 Cement TRD PRO
    Which is why I am wondering if those holes are deformed
  13. Jun 14, 2019 at 8:49 AM
    PJTACO
    2017 Cement TRD PRO
    UPDATE: they agreed to remove my LCA bolts and in order to allow me to inspect them. I inspected, and the bolts and the holes were in good shape, and showed no signs of excessive wear.
    I'm not sure what this clack is, and I have no proof of the alignment. They've agreed to refund my 3 years alignment plan.
