HELP: headlights stay on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by andrewp, Jul 7, 2010.
  1. Jul 7, 2010 at 11:38 AM
    andrewp
    andrewp [OP] New Member
    hi guys,
    05 tacoma with DRL
    http://www.tacomaworld.com/forum/technical-chat/1475-05-drl-daytime-running-lights-install-oem.html
    (might not even be related, but maybe)
    i've always left the lights in the "auto" setting. worked fine since i've owned it, and even months after the DRL install.
    occasionally, i would realize after i get out of my car and locked the door using my key fob, the headlights stayed on (usually they turn off when it arms). this has been getting progressively worse, and has left me stranded with a dead battery on several occasions. i can't always reproduce it, but it seems either when i open the door again, or close the door again, it does off.
    i've visually checked the door pin contact and it's not all gunky, seems ok.
    has anyone had this problem? i'm probably going to start ripping things apart to get to the bottom of this, but is there a particular system i should start with? does this sound like a wiring issue? faulty door switch? console switch? DLR causing problems?...
    thanks!
  2. Jul 7, 2010 at 12:25 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 4Runner TRDOR Prem. MGM
    I dont know man, sounds like it is in the door to me, somewhere in the switch. Anyway I would just start turning off the headlights manually before getting out of the truck. Hope you find out the problem, keep us posted.
    Someone will chime in soon
  3. Jul 7, 2010 at 11:34 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    x2
    I would start with the door switch. It's probably cheap and is easy to replace. Until you find it for sure though I would keep turning them off manually (prevents the dead battery crap).
  4. Jul 8, 2010 at 12:12 AM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    we have an auto setting? wtf?
  5. Jul 8, 2010 at 2:58 AM
    005Tacoma
    005Tacoma Well-Known Member
    Thomasville, Georgia
    2005 Toyota Tacoma
    Yes. You can turn your headlights on and turn your key all the way to start engine. You don't have to crank up. Just turn ignition off and open your drivers door. Headlights will turn off. Then next time you go driving your headlights will come on automatically.
  6. Jul 8, 2010 at 4:17 AM
    Kelson
    Kelson
    Honolulu, Hawaii
    oh i thought he was talking about a true "auto" feature, as in light sensitive, turning the headlights on when its dark and turning them off when it's bright..
    all toyota's do that...i thought it was just on. i don't leave my headlights on during the day....
  7. Jul 8, 2010 at 8:26 PM
    BLacTaco
    BLacTaco Well-Known Member
    Zabdi
    Los Angeles
    07 PreRunner SR5 Black
    im having that same problem!!!
  8. Jul 8, 2010 at 9:26 PM
    KaoskrewPB
    KaoskrewPB -Empty-
    Not to thread jack buy does anyone know how to turn off the yellow parking lights?
    I have 3 settings, the off one has only the parking lights on, the middle one turn on the corner lights and leaves Parkin lights on, and the 3rd one turns on the headlights...
  9. Jul 8, 2010 at 9:41 PM
    Sidehack
    Sidehack Well-Known Member
    Chuck
    Simi Valley
    07 DC Long Bed Sport
    Black Westin Oval Step Bar, Blacked out tail lights, ScanGuageII
    I have the same problem with my '07. The turnsignal lights are on if the headlights are off. I would like to have nothing on during the day. How can I turn off the stupid daylight light running light thing?
    Is it one of those turn on the key, honk your horn, slide the seat back, and smack the horn routines to change the setting?
  10. Jul 8, 2010 at 10:27 PM
    KaoskrewPB
    KaoskrewPB -Empty-
    Lmao.
    That "slide the seat back" was hilarious.
    I really wouldn't mind one of those methods as long as they turn off when I turn the damn switch to "OFF"
  11. Jul 8, 2010 at 10:38 PM
    warpwr
    warpwr Junior Senior Member
    Vaughn
    S.F. Bay Area
    09 Sport Access Cab
    DRL mod with switch, rear spring TSB, trans TSB, tailgate mod, snug-top shell.
    I mod my truck so I can get the ambers on all the time and you want your factory DRLs off....
    anyway, to answer your question, you can cut the green and red wire or run it through a switch like I did. It's all in the DTRL mod thread below.
    http://www.tacomaworld.com/forum/te...rl-daytime-running-lights-install-oem-10.html
