Help help help
Discussion in '1st Gen. Tacomas (1995-2004)' started by beefcake, May 27, 2010.
  1. May 27, 2010 at 11:51 AM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    im trying to get my old ps pump off and i cant get the return line off on the bottom of the pump its a 17mm and it wont budge, i've tried penetrating oil and some leverage but it's not moving, any advice would be appreciated
  2. May 27, 2010 at 11:58 AM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    More penetrating oil and tap it with a hammer. Just dont hit it to hard and srew it up. Sometime just the vibrations will help.
  3. May 27, 2010 at 12:01 PM
    bigburrito
    bigburrito Local Man
    DuPage County
    '09 TRD OR
    Demello sliders, fog lights anytime, 265/75R16 Duratracs, 60" HiLift, VIAIR OBA 2.5 gallon tank, FM Super 44, TSB springs, 5100s at .85, bent tailgate
    heat it up with a torch
  4. May 27, 2010 at 12:03 PM
    mwild
    Vernon, NJ
    03 2500 Dodge Ram
    Thats a last resort. I can light on fire if their is any PS fluid on it and i will burn the hose and you will have to replace the hose or risk it blowing out on the road.
  5. May 27, 2010 at 9:56 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    hitting it with the hammer helped, ended up with some vice grips, a coupld buddies and some pipe to get enough leverage to break the nut loose, got the pump on and works great
