Help help how can i gear it down
Discussion in 'Performance and Tuning' started by mattcombs, Dec 24, 2009.
  1. Dec 24, 2009 at 7:22 PM
    mattcombs
    mattcombs [OP] Well-Known Member
    matt
    hazard kentucky
    SR5 tacoma 4wd
    3in revtec lisf westin step bars and westin bull bar and some other odds and ends
    i have an 08 tacoma 4x4 and im putting 305 70 16 dick cepek mud countrys on it i know i need to gear it down because ive only got a 2.7 but im wondering if i can go ahead and buy a lower gear set that has the electric locker option and put the locker on a month or so down the road and what ratio should i gear it i dont really care about speed i only live around 2lane roads with a 55 speed limit
  2. Dec 24, 2009 at 7:57 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    What kind of lift do you have under that??
    I don't think you'll find an electronic locker....ARB Air Locker or a Detriot TruTrak...but that's about it I think.
    Not sure what ratio to tell you to go to...but the tire calculator on the site (in the menu bar in the Wheels and Tires forum) is pretty helpful...
  3. Dec 24, 2009 at 7:59 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    i have the revtec 3 in
  4. Dec 24, 2009 at 7:59 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    with what lift?
    gearing should be fine for moderate off-roading.
  5. Dec 24, 2009 at 8:07 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    i just thinkit will make me a lot weaker on take off figured gearin it a little lower would help
  6. Dec 24, 2009 at 8:10 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    so the larger the gear ratio the lower the gearing is right?
  7. Dec 24, 2009 at 8:13 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Thats correct. The Higher numerically the lower the gearing. You most likely have 4.10 gears, I would stick with those.
    What is your stock tire?
  8. Dec 24, 2009 at 8:14 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    it came stock with 245 but im runnin 265 75 bfgs right now remember i have 2.7 4 cyl
  9. Dec 24, 2009 at 8:19 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    245 what? I'll need all three numbers. How about give me the stock size ???/??/?? then the tires you are running now, and the size you will run in the future.
  10. Dec 24, 2009 at 8:19 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    you can gear it down to 4.56 and be close to stock power to the ground. But with the added weight youll get less mileage and less acceleration
  11. Dec 24, 2009 at 8:24 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    stock was 245 75 16 now is 265 75 16 and later 305 70 16
  12. Dec 24, 2009 at 8:26 PM
    Yoytoda
    Roland
    completely stock
    he said stock 245s...245/75-16= 30.5"x 9.5" x 16"
    now he has 265/75-16s= 32"x 10.5"x16"
    He wants 305/70-26= 33"x12" x16"
    If you go with a narrower tire like 255/85-16 you get a 33" tire thats 10" wide= alot less trimming. Also, 12" wide tires require 9" wide rims.
  13. Dec 24, 2009 at 8:28 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    do you think 4.88 would be to much i just do want to have to wind the crap out of it i dont really care it it top out at 75 lol
  14. Dec 24, 2009 at 8:29 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    im gettin xd series wheels to gona put an offset not real sure how much trimming but dont think it will be to rediculous just have to try i sure do appreciate yall helpin me out
  15. Dec 24, 2009 at 8:31 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Ok so your stock tire was 30.4" tall and your gear was 4.10
    On your truck now is a 31.6" tall tire and your gear is 3.94
    You want a 32.8" tall tire, your gear will be 3.80
    I have some 33" tall tires with stock 3.73 gears. Seeing as my tires are taller than stock I have less gear than that something like 3.50 or so I'm guessing becasuse I don't want to do the math. I think your stock gears should be ok. Thats my $.02
    Oh and I think the 305's would be too wide, and heavy.
  16. Dec 24, 2009 at 8:33 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    but your truck has the 4.0 v6 i have 2.7 4cyl
  17. Dec 24, 2009 at 8:34 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Oh yeah but don't count that little guy out. I wheel with jeeps that are making the same if not less hp and tq than you and they are doing just fine for the avid wheeler. These are also daily driven vehicles. I've been drinking and can't recall the specifics right now which is why I asked you to post your tire sizes completely, because its a jumble right now. Back to my point though, I believe you are making enough torque to not have issues with your take offs. You'll notice it but I don't think it'll be that bad, I certainly don't think it will cost you any mpg. With the exceptions of the weight of the tires. I would look for something skinnier. Just my opinion, I would also think there would be a bit of rubbing on your UCAs with those tires. You can play with the back spacing but only so much.
  18. Dec 24, 2009 at 8:36 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    buddy i sure do hope your right lol thanks for helpin me out im gona get my wheels and tires and get the trimming and spacing lined out and hope i dont need it thanks for helpin me out merry christmas
  19. Dec 24, 2009 at 8:39 PM
    Yoytoda
    Roland
    completely stock
    with 33" tires 4.11 (stock) would work but give you no power. 4.56 would give you the equivelant power of stock gearing with stock tire. 4.88 will give increased power but kill highway driving as you will winde it out while cruising...like driving in 4th gear at 65 mph
  20. Dec 24, 2009 at 8:41 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    4.56s will be the way to go. If your really looking for some extra gear you could go with the 88s. You need to keep in mind that your tire isn't just tall it is wide which causes two things, one being rolling resistance and the other being weight, and lots of it. With the lack of power the 2.7 puts out, you would be foolish to not go with at least a 4.56.
