Help help how can i gear it down
Discussion in 'Performance and Tuning' started by mattcombs, Dec 24, 2009.
  1. Dec 24, 2009 at 8:41 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Any time thats what we are here for. And no matter what you can install the wheels and tires now and see how you like it. Then do the gears later. It's pricey and quite a bit of work. I have some 4.10 gears sitting on my floor now that I bought. I was like you planning to regear and find I don't need to but for the price of these gears I couldn't say no. Besides it'll get me back to stockish. Have a very Merry Christmas!
  2. Dec 24, 2009 at 8:41 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    305s are rediculous and with aftermarket rims you are more than likely going to need to do the cab mount mod and probably UCAs
  3. Dec 24, 2009 at 8:43 PM
    Yoytoda
    Roland
    completely stock
    why not 285/75s
    even they require quite a bit of trimming
  4. Dec 24, 2009 at 8:47 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    ^ He's right about the tires being too much. I'd as he suggest 285's
    Stock 2.7 is rated at what about 160 hp and 180 tq. My 02 V6 was barely better than that, and I ran 33's. I'd try it before I spent tons of money on regearing. No doubt that you would like some 4.56 gears. It all depends on you in the end. gears will cost a pretty penny especially to have somone other than yourself install them.
  5. Dec 24, 2009 at 8:48 PM
    mattcombs
    mattcombs [OP] Well-Known Member
    matt
    hazard kentucky
    SR5 tacoma 4wd
    3in revtec lisf westin step bars and westin bull bar and some other odds and ends
    would i be better off with an 11 and a half in tire?
  6. Dec 24, 2009 at 8:52 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    thats still a 33 in tire right just not as wide
  7. Dec 24, 2009 at 8:53 PM
    Yoytoda
    Roland
    completely stock
    Dont forget that a revtec lift wont cut it... you need ucas to clear wider tires too.
    My plan is getting COs and UCAs then getting 255/85 16s. they are 33"x10" 16"s. Way fewer clearance issues and the fit on stock rims.
  8. Dec 24, 2009 at 8:53 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    ^ good call on that size, not to mention saving some money on rims.
    Certainly, the skinnier the better, within reason. Width adds alot of weight and resistance.
  9. Dec 24, 2009 at 8:57 PM
    Yoytoda
    Roland
    completely stock
    and being narrower they are lighter= less rolling resistance. the truck is light enough that narrow tires still provide enough floatation and if driven in snow provide good traction because they cut through to pavement
  10. Dec 24, 2009 at 8:57 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    what is COs and UCAs
  11. Dec 24, 2009 at 9:00 PM
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    i think ill go 285 75
  12. Dec 24, 2009 at 9:01 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    CO's= Coilovers. UCA's are Upper Control Arms.
  13. Dec 24, 2009 at 9:08 PM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    I also have a 2.7L 4x4 and re-gearing is a necessity. It would be ridiculous to put 33s on your truck without re-gearing. I didn't even like the power loss that resulted from putting on 32s. In 5th gear, I could hardly keep it at 70mph if there was a head wind until I got a K&N air filter.
    When I re-geared I got 4.56 because I intend to get 33s eventually. 4.56 gears will put your final ratio back to stock.
    My suggestion for tires would be 255/85/16 (33x10). With as light of a truck as you've got, you don't need a very wide tire. If you start actually doing friction calculations, you can see that all that extra surface area can hurt your overall traction. My $.02
  14. Dec 24, 2009 at 9:10 PM
    drew02a
    San Antonio, TX
    also 255/85/16 won't require new UCAs and the trimming involved will be minimal.
  15. Dec 24, 2009 at 9:13 PM
    #35
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I would listen to drew. Despite all I said my comments were not from actual experiences with your truck. His comments are very valuable here. He's been there and done that. Also the man to ask about doing the regear, as he has done his himself. I hate to be wrong or give bad advise but his personal experience trumps me. lol. I didn't want to push you into purchasing gears right off hand if maybe you would be content with the stock ones.
    Drew do the 2.7s lack the low end torque as well as in higher rpms? One of the jeeps I wheel with is old as dirt and makes around 100hp, he has 33's and some 4.10s. No issues there. What is lacking in ya'll trucks? Could it be the gearing in the tranny?
  16. Dec 25, 2009 at 7:43 AM
    #36
    drew02a
    San Antonio, TX
    Is your friends jeep an automatic? Not having the right gearing is more of a problem with a manual transmission, because the clutch can't take the same kind of abuse as a torque converter. When the gearing is wrong in an auto, its way less noticable because the torque converter just slips more (bad in the long run).
    Your advice would be spot on for the 4.0L Autos, but for the 2.7L manuals it's a different story.
  17. Dec 25, 2009 at 3:16 PM
    #37
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    yall think i would need UCAs and COs if i bout wheel spacers and hoe much of a spacer would i need
  18. Dec 25, 2009 at 3:38 PM
    #38
    drew02a
    San Antonio, TX
    if you got spacers you wouldn't need UCAs. You'd have to do more trimming though.
  19. Dec 25, 2009 at 6:12 PM
    #39
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    More trimming to the wheel well? mud flap or what? Wut kind of ucas would i need
  20. Dec 25, 2009 at 6:34 PM
    #40
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    for a 285 75 will i need a 16 8 or a 16 9 inch wheel?
