Help help how can i gear it down
Discussion in 'Performance and Tuning' started by mattcombs, Dec 24, 2009.
  1. Dec 25, 2009 at 6:57 PM
    #41
    mattcombs
    mattcombs [OP] Well-Known Member
    matt
    hazard kentucky
    SR5 tacoma 4wd
    3in revtec lisf westin step bars and westin bull bar and some other odds and ends
    good i wanted to stay with 8
  2. Dec 26, 2009 at 6:03 PM
    #42
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    It certainly was an auto. Thanks for chiming in and giving better advise. I never thought to consider auto or manual for the op's situation.
  3. Dec 26, 2009 at 7:30 PM
    #43
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Keep in mid that Randy is one crazy wheelin' mo fo
  4. Dec 28, 2009 at 11:20 AM
    #44
    mattcombs
    matt
    hazard kentucky
    SR5 tacoma 4wd
    got it all figured out lol
  5. Dec 28, 2009 at 11:42 AM
    #45
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    Not sure if this is true...i'm runnin 16x8 with my 12 inch wides.
  6. Dec 28, 2009 at 3:57 PM
    #46
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    its suggested to run a 9in wheel. the tire will wear more in the center. the sidewalls wont be straight either making for a squashy ride. rule of thumb is keep the tires less than 2in wider than the rims. 12" tires on 8" rims is pushing it
  7. Dec 28, 2009 at 4:00 PM
    #47
    Yoytoda
    Roland
    completely stock
    bottom line rim width alters tire profile. profile is the contact patch on the road. wheels to wide for tires makes a negative profile wearing the outside of the tread, also makes it easy to break the bead in an aired down situation
  8. Dec 28, 2009 at 4:58 PM
    #48
    gjbonner
    Guy
    Northern Idaho
    Yeah i still dont really agree with that too much. but thats just me. 12 inch tire on a 10 inch rim or wider just isnt right. sidewall difference is really minimal and as for a squishy ride...well i get this anytime i go to bigger tires with any pickup ive owned. its always a softer ride because your adding more rubber to the sidewall...well that is if your not running 18" rims or something crazy like that. And for offroad, the more side wall the better. As for wear, you just need to find the right tire pressure for your setup.
    Which is the reason I like to stay on the more narrow side of rims but obviously not in the ridiculous realm:)
    Just my thoughts and experience on the subject FWIW
