***HELP*** HID'S won't work anymore!!
Discussion in 'Lighting' started by Albertataco89, Jul 17, 2014.
  1. Jul 17, 2014 at 8:28 PM
    Albertataco89
    Albertataco89 [OP] Well-Known Member
    Joey
    Alberta
    09BlackLiftedSR5
    Arb winch bumper, M8000 warn winch, 6 inch BDS lift, mayhem wheels, kenwood all around
    So I installed a dual battery system into my 09 tacoma and when I hooked everything back up my HID'S won't work? When I turn my high beams on the lights adjust for the high beams but no light at all from either of the HID'S ..!! I am going on vacation and need it fixed asap!! I checked all the wiring and fuses the only thing left to replace are the ballasts? Has anyone ever experienced anything like this before or have any ideas on what it could be!!
  2. Jul 17, 2014 at 8:33 PM
    IgnorantlyAlberta
    IgnorantlyAlberta VA6DCO
    David
    edmonton
    06 sr5 tacoma rear shock relocate, 35s
    lift, wheels, bumper, rear bumper, intake, front and rear winches, swing tailgate, OBA, sliders.
    Do you have it hooked through the stock lights power for the switch or do you have an aux switch?
    Have you pulled the fuses out and put them back in? I've found the fuses get hot and melt the plastic surrounds sometimes.
    Do you have 12v before the ballasts?
    Can't quite get more into it. Pretty much the reason I pulled mine out.
    What brand you go with?
  3. Jul 17, 2014 at 8:41 PM
    Albertataco89
    Joey
    Alberta
    09BlackLiftedSR5
    Yes it is plugged into the stock driver headlight to receive the signal I got them from HID'S r us they are 55w bixeon
  4. Jul 17, 2014 at 8:42 PM
    Albertataco89
    Joey
    Alberta
    09BlackLiftedSR5
    And yes I did pull the fuses the ones in the stock fuse block and the ones in my aftermarket fuse block which is actually powering the ballasts
  5. Jul 17, 2014 at 8:55 PM
    A7xschecter6661
    A7xschecter6661 InSight Retrofits Official
    Pete
    13901, NY
    are you using a relay harness? There is a fuse on them usually and that's what would probably go
  6. Jul 17, 2014 at 9:04 PM
    Albertataco89
    Joey
    Alberta
    09BlackLiftedSR5
    I will have to double check on that I took it apart and a bunch of water came out of it but I didn't notice a fuse, they are getting power because they switch from low to high beam but just no light?
  7. Jul 17, 2014 at 9:04 PM
    Albertataco89
    Joey
    Alberta
    09BlackLiftedSR5
  8. Jul 17, 2014 at 9:59 PM
    IgnorantlyAlberta
    David
    edmonton
    I would pull everything apart and start from scratch. Make sure the splices or connector pins are making good contact. Just go from start to finish.
  9. Jul 18, 2014 at 5:20 AM
    Albertataco89
    Joey
    Alberta
    09BlackLiftedSR5
    That's what I'm going to do after work but I think I might of fried something because it only happened after I put my dual battery kit in, the battery's are wired up to be a 12 volt circuit though so I don't know how it could of damaged anything
  10. Jul 18, 2014 at 5:47 AM
    IgnorantlyAlberta
    David
    edmonton
    Isolated circuit?
  11. Jul 18, 2014 at 2:24 PM
    theblindchicken
    theblindchicken Well-Known Member
    Christian
    Long Beach
    '74 K10
    HID's, LED Dash swap, LED reverse lights, 15"x10" 5 slot mags, sliding rear window, 20gal aux. DS fuel tank,
    Do your ballasts have their own grounds?
  12. Jul 19, 2014 at 4:03 AM
    Albertataco89
    Joey
    Alberta
    09BlackLiftedSR5
    Yes they both have their own grounds
  13. Jul 19, 2014 at 4:14 AM
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    You had water inside the relay harness? Mine did that and shorted out eventually. I had to replace the harness and they started working again.
