help hooking up arb fog lights and turn signal/ dtrl combo on a reg cab..
Discussion in 'Lighting' started by stunt man hans, Aug 2, 2011.
  1. Aug 2, 2011 at 2:18 PM
    stunt man hans
    stunt man hans [OP] DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    i have the required harness MD02 and i'm about to begin wiring the fogs and signals but, just like the bumper install the directions are not very clear...
    i know i want to hook the fogs into the the low beam wire on the headlight for a specific reason so any help on locating the low beam power wire on the driver side would be a big help.
    the turn signal/dtrl combo lamp i have no clue:confused:
    my truck does not have factory fogs nor does it have dtrl from the factory so what would be the best way to get full functionality with this set-up.
    i also don't have a volt meter so this is not helping matters either:eek:
  2. Aug 2, 2011 at 2:28 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm not near my truck so I can't help you with the wiring but a test light can be your best friend when figuring out wiring. Simplier than a volt meter, you just ground it and when you touch something 'hot' it lights up. You should be able to get one cheap at a local auto store or even a place like Sears. Good luck, I'm jealous, I'd love to have an ARB :D
  3. Aug 2, 2011 at 3:36 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    cool thanks mike! at first i thought retarded 4wp's was going to send me 2 of them if that was the case i would have given you one lol..
  4. Aug 2, 2011 at 8:15 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    bump for an awesome question...
    if my truck does not have dtrl's can i make the arb ones work?
  5. Aug 3, 2011 at 7:51 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    ok as of right now i'm ready to begin pulling hair out.
    i have the turn signals and marker lights hooked up properly...
    now the problem is with the MD02 harness arb sent me to hook up the arb fog lights in the bumper i have followed diagram #1 on the instruction sheet as per the arb tech earlier on the phone. the connections are made at the fogs them selves the relay is plugged in properly the 2 red wires are routed into the cab i even made a ground for the switch the fuse is in the fuse holder ground and power are connected wtf!???
    there is one connector i was told i would not need and i was told to cut it off by the tech today but now what do i do with the wires there is a red wire that is one of the switch wires and the is a black wire which i would assume to be a ground how do i make this work and what do i do with the two exposed wires from where i cut the connector off do they go to the trucks harness i was going to put the arb fogs the the low beams on my factory headlights
    i need assistance from someone who has hooked these up previously and has experience with arb's fucking retarded wire loom
  6. Aug 3, 2011 at 8:27 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    bump need some help here
  7. Aug 4, 2011 at 12:46 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
  8. Jan 21, 2012 at 8:23 PM
    huntark03
    huntark03 I'd rather be hunting!
    Maumelle, AR
    2005 Limited Tundra DC 4X4
    Spidertrax Wheel Spacers aFe Pro Dry Drop in Air Filter Weathertech Liners Bilstein 5100s w/ OME 885 coils and ToyTec 1.5" AALs Light Racing UCAs
    Do you remember how you wired up the marker lights...I'm at a loss here??
  9. Jan 21, 2012 at 8:33 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    i had actually made this thread before i got the correct harness i was in fact missing a piece.
  10. Jan 21, 2012 at 8:35 PM
    huntark03
    Maumelle, AR
    So I may be missing the correct harness...
