help, how bad's my mpg
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DirtKing, Apr 27, 2012.
which tire size with a width of 11.5 to 12 in.
Poll closed Jul 16, 2012.
  1. 33
    71.4%
  2. 35
    28.6%
  1. Apr 27, 2012 at 12:58 PM
    DirtKing
    DirtKing [OP] Member
    Bryan
    Rancho Cucamonga, Ca.
    09' 4x4, TRD Sport, Debaged,
    so i have my truck stock for the most part, but would like to make it into as street liegle as possible trophy truck or prerunner what ever you like to call it. my trucks an 09' tacoma access cab 4x4 v6. and i want to put some big beefy tires but not too high that i get horrible mileage that i should just get a jeep. i was thinking 11.5 to a 12 in width and either a size 33 or 35. what are the ups and downs to each size as well as performance and mpg. any help would be sweet.
  2. Apr 27, 2012 at 12:59 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Just regear accordingly.
  3. Apr 27, 2012 at 1:57 PM
    DirtKing
    Bryan
    dont see how that works, explain??
  4. Apr 27, 2012 at 2:22 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Taller tires reduce your overall gear ratio from engine to the ground so you compensate by adjusting your differential gears.
  5. Apr 27, 2012 at 2:39 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    My head is spinning. So the title is about MPG's but your asking how big of a tire you can get because you want to be a street legal trophy truck? You do know that tires do not make it a trophy truck right? And the word your looking for is legal
  6. Apr 27, 2012 at 2:46 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
  7. Apr 27, 2012 at 2:48 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
  8. Apr 27, 2012 at 2:53 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Hermosa Beach
    08'
    6" Ruff Country DBL
  9. Apr 27, 2012 at 3:01 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
  10. Apr 27, 2012 at 3:02 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    ^^can I haz??
  11. Apr 27, 2012 at 3:02 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Bigger tires = worse gas mileage. It's that simple.
    You gotta pay to play.
    Honestly, regearing only marginally helps you around town (in terms of gas mileage) and only if you have a light foot. It doesn't help you at all the freeway (in fact you'll get worse due to running higher RPM at cruise speed).
  12. Apr 27, 2012 at 3:16 PM
    bluetaco80
    bluetaco80 Well-Known Member
    Rob
    fullerton ca
    06 prerunner dc sb longtravel
    Full engage longtravel front and rear
  13. Apr 27, 2012 at 3:18 PM
    bluetaco80
    Rob
    fullerton ca
    Looks like he hit the gas pedel too soon causing him to do that
  14. Apr 27, 2012 at 3:19 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I doubt he ever let off the gas pedal!
  15. Apr 27, 2012 at 3:20 PM
    MartyMcfly
    MartyMcfly Time Traveler
    ROB
    Crapwater Floriduh
    15' 4runner Limited 4wd
    see Build page for details.
  16. Apr 27, 2012 at 3:20 PM
    bluetaco80
    Rob
    fullerton ca
    Or that too lol
  17. Apr 27, 2012 at 3:21 PM
    SoCalRoadie
    SoCalRoadie Well-Known Member
    Jim
    Burbank
    10 PreRunner TRD 2wd Engage LT
    Its when a lesbian hits on RJ and realizes its :rjallday: and jumps back in shock.
  18. Apr 27, 2012 at 3:31 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    sub'd for some laughs
  19. Apr 27, 2012 at 3:31 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Slap some 37" bfg t/a's on it and call it a day, trophy truck stats fo sho bro!
    265/75/16 is biggest u could go with out trimming and lifting (might need small lift not sure) or 285/75/16 with some trimming/body mount chop and some lift. Guys are running the next size up too but it all depends how much u wanna spend to make it work properly.
    Also is this just for looks or do u plan on using it?
  20. Apr 27, 2012 at 3:33 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    i hope he's planning to use it. he's building a trophy truck BRO!!!
