Help! How do I handle this stripped/seized bolt? (pic)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoman100, Oct 6, 2019.
  1. Oct 6, 2019 at 5:06 PM
    #41
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Back up back up plan is driving with 3 bolts in that joint.
  2. Oct 6, 2019 at 5:09 PM
    #42
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Highly do not recommend lol
    Although if he had to limp it to a shop via city streets that way itd probably be fine.
    Tacoman100[OP] likes this.
  3. Oct 6, 2019 at 5:36 PM
    #43
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Watch out for advice from 3rd Genners on 1st Gen forums.
  4. Oct 6, 2019 at 5:39 PM
    #44
    Tacoman100
    Tacoman100 [OP] Active Member
    So... torching doesn’t seem like it’d work without totally massacring the rubber on the ball joint. May just have to do it and replace the ball joint
  5. Oct 6, 2019 at 5:49 PM
    #45
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Well, it looks like your way deep in fighting that bolt. But to answer your question. You could have just popped the LBJ loose from the LCA and changed out your CV. You still can but the integrity of that bolt is most likely shit right now. Grind it off and swing the spindle out of the way. Get a pair of locking pliers on the stud and heat and hammer ever so gently. It's threaded into the spindle and if you bugger the spindle threads you just opened up a whole new can of worms.
  6. Oct 6, 2019 at 5:54 PM
    #46
    RedRooster4X4
    RedRooster4X4 Well-Known Member
    Southern Maryland
    2015 tacoma 4x4 DCSB Limited
    3" lift 285 nitro terra grappler
    Easy with the heat, dont make direct contact with rubber & Use a wet rag to keep rubber cool
  7. Oct 6, 2019 at 5:56 PM
    #47
    Tacoman100
    Gotcha. At this point it’s personal, so that bolt is coming out one way or another. Thanks for the suggestion though. Good to know for the future!
    bigmw and theesotericone[QUOTED] like this.
  8. Oct 6, 2019 at 6:00 PM
    #48
    theesotericone
    Bishop CA
    I just posted it for the next guy that finds this. lol
    As far as heat goes. You don't want to be heating the bolt or the LBJ. You want to put the heat on the spindle where the LBJ bolt threads into it. That allows the metal around the bolt to expand. I still can't believe it's being that much of a PIA if it was just installed. Either someone got super happy with the impact, super happy with the red loctite, or they cross-threaded it. I hope it's not the latter. lol
  9. Oct 6, 2019 at 6:00 PM
    #49
    GQ7227
    GQ7227 mw survivor
    J A Y
    a 3rd genner gave me advice to buy a new truck, that mine has had a good run of 22yrs and yada yada yada
    of course I was in the 2nd gen forum at the time so i asked for it lol
  10. Oct 6, 2019 at 6:03 PM
    #50
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    What @dewayne told you i a great idea. If I may suggest instead of a socket find a nut you can just hammer over the bolt head and weld it to the bolt head. You can then ue a ratchet or impact to pop it out. The combination of the beating the nut on and the heat from welding and it should pop on out fairly easy
  11. Oct 6, 2019 at 6:07 PM
    #51
    IvanhoeTaco
    Eastern NC
    If you get this much response from 1 bolt just imagine your build thread following!
  12. Oct 6, 2019 at 6:09 PM
    #52
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    I think some of us just like to figure out how to fix problems.
    OP if you can find a set of stud pliers they may work as well. They look kinda like a regular set of channel locks but are curved in a way that when you pull on them they put a bind on the bolt or stud and help get it turning
    Tacoman100[OP] and dewayne like this.
  13. Oct 6, 2019 at 6:17 PM
    #53
    dewayne
    dewayne Simply Southern.
    Dwayne
    Shenadoah Valley,Virginia
    2015 tacoma AC mettalic grey
    265/75r16 KO2 5100 level at1,75,Icon 3 leaf addaleaf pac,amp,speakers,holster,black out badges
    2nd Gen! brother. lol. first one was 1986
  14. Oct 6, 2019 at 6:21 PM
    #54
    dewayne
    Dwayne
    actually you are right Chris. we welded a nut to the one with a stripped out allen head. my bad on the socket. been a long weekend! thanks bro!
  15. Oct 6, 2019 at 6:25 PM
    #55
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    :thumbsup: You were right though a socket can work as well the nut is just a little easier to weld to. Regrettably I know this too well. Looks like you had a fantastic weekend congrats on that friend
  16. Oct 6, 2019 at 6:30 PM
    #56
    Tacoman100
    It being a PiA is actually not a bad thing. Once I get this thing out, I will no longer fear the dreaded seized/stripped bolt.
    side question: I just paid $1K to replace the LCAs. Earlier I went out and saw my dad hammering at it horizontally where the Ball joint meets the LCA. He didn’t go crazy but I heard him bang it some. How sensitive are LCAs to this time of banging? Should I worry about this at all?
    Love my truck so I don’t want it messed up.
  17. Oct 6, 2019 at 6:44 PM
    #57
    eon_blue
    Azusa, CA
    I wouldn't worry about it
    Was he trying to separate the ball joint? Hammering it is a common way of doing so, though I'd rather use a pitman puller. You have to whack it good with a hammer to get it to pop out.
  18. Oct 6, 2019 at 6:55 PM
    #58
    theesotericone
    Bishop CA
    You're fine. I wheel the crap out of my rig and my LCA's haven't bent at all. They're a very solid component. I've bent or broken just about everything else in the front end but the LCA's are still original. I just replace the bushings every 6 months. lol
  19. Oct 6, 2019 at 6:56 PM
    #59
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I would of tried beating a smaller socket on it first then hitting it with an impact. Now you rounded it out more with the chisel causing bigger problems for yourself
  20. Oct 6, 2019 at 7:06 PM
    #60
    Tacoman100
    Yup exactly. Awesome thanks
    eon_blue[QUOTED] likes this.
