Help! How do I handle this stripped/seized bolt? (pic)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoman100, Oct 6, 2019.
  1. Oct 9, 2019 at 7:39 AM
    #121
    TacoTaco02
    TacoTaco02 Well-Known Member
    Illinois
    02 Ext Cab SR5 TRD 4x4 V6
    I know you got the bolt out but Milwaukee makes some great vice grips. The adjustment knob has a hole in it so after you clamp on to something you can stick a screwdriver in it and crank it down. Has saved me multiple times.
    Bingo. My 12pts are all hidden away and rarely used.
  2. Oct 9, 2019 at 1:06 PM
    #122
    paetersen
    paetersen Well-Known Member
    HAHAHAHAHA! And then the bean counters said "8.8 will be plenty good enough for 99% of the time and save us $0.12 a unit."
    Also, SAE vs metric grading is a little confusing sometimes. a grade 5 SAE bolt is closest in hardness/strength to a Metric 8.8 and grade 8 SAE is roughly 10.9. I wouldn't hesitate to put 10.9 in any application that originally had 8.8 as it is still not hard enough to be brittle.
