HELP hubcentric spacers fit on a 98 Tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jebediah, Mar 29, 2017.
  1. Mar 29, 2017 at 10:10 AM
    Jebediah
    Jebediah [OP] Well-Known Member
    Eli
    Colorado
    1998 White TRD.. 'Augustus'
    After starting to run 285/75 r16s on stock 3rd gen 4runner rims, I realized I am in need of some spacers. I have read up extensively and it seems that the general consensus is that spidertraxx are awesome and hub centric is the way to go.
    HOWEVER, after calling Toytec to confirm that the hubcentric ones fit on my 1998 3.4l 4wd TRD Tacoma, they said they won't. Wheeler's Offroad said that they would. So basically I'm totally lost and I need some help. Anyone with a 98 running hubcentrics? Any input would be greatly appreciated. Toytec said that my hubs are a different size than the 2001+ tacoma however I am running 3rd gen 4runner wheels which fit great on my truck and the hub centric spacers are supposed to fit on 3rd gen 4runners so wouldn't they do fine on my truck? Please help.
  2. Mar 29, 2017 at 10:40 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Your hubs are the same size as every other 1st gen, and your wheels are hub centric. Spidertrax will fit perfectly, and are one of the best quality spacers you can get.
    FWIW, calling parts vendors to get fitment info is hit or miss at best. Most of them are just selling parts, they don't know everything about every model.
    Jebediah[OP] likes this.
  3. Mar 29, 2017 at 10:42 AM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    Eh, I'm pretty sure it depends if his hubs are manual locking or not.
  4. Mar 29, 2017 at 10:47 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    1.25" spacers will need modification to fit (use a dremel to shave a little material where the hub nuts hit). 1.5" and up should fit without modification.
  5. Mar 29, 2017 at 10:55 AM
    Jebediah
    Eli
    Colorado
    I do not have manually locking hubs...
  6. Mar 29, 2017 at 11:15 AM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Good call, I was not aware there was an issue with fitment on manual hubs.
    Doesn't sound like that will be a problem here though.
    WildLand likes this.
  7. Mar 29, 2017 at 11:19 AM
    Jebediah
    Eli
    Colorado
  8. Aug 18, 2017 at 2:47 PM
    taco71742
    taco71742 Well-Known Member
    Daniel
    Woodstock GA
    04 Taco DC 4x4 5spd
    3" Toytec Boss Lift with External reservoir and adjusters Prerunner to 4x4 conversion Manual locking hubs 16x10 w/-38 offset 305/70r16 Toyo RT tire
    Hate to revive this thread but If I have manual locks, do i need to go with the 1.5" spacer? Their website says that the 1995-2000 require the 1.5 and the 2001-2004 require the 1.25.
