Help, I broke the truck!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4lo, Jan 11, 2013.
  1. Jan 11, 2013 at 2:27 PM
    4lo
    4lo [OP] Well-Known Member
    El Campo, TX
    2017 TRD Sport
    some stuff
    Ok... So I ran into a concrete block this afternoon (no smart ass remarks please) with the wheel turned full left and only about 3 miles an hour. Now the wheel on the drivers side (impact side) is hitting the uca... So I'm at least an inch outta camber if not more. I've got the whole thing apart and no sign go anything bent or broken.... Ideas on what I may have efffed up or is it possible to throw the alignment so far out the the tire hits the suspension?
  2. Jan 11, 2013 at 2:28 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    how do your alignment tabs on the LCA mounts look?
  3. Jan 11, 2013 at 2:30 PM
    4lo
    El Campo, TX
    2017 TRD Sport
    some stuff
    I'm lookin. Searching pics for reference.
  4. Jan 11, 2013 at 2:32 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Possible for the actual spindle to be bent as well..
  5. Jan 11, 2013 at 2:33 PM
    logcabinwc
    logcabinwc Well-Known Member
    Micah
    SF East Bay
    08 4d 4x4 White V6 TRD
    Old Man Emu 885s with Nitrocharged 90000, Bilstein 5100 in the back with AllPro 3 spring progressive AAL, 16 inch Baja Black 6-spoke alloy wheels, Flow Master exhaust, bed lights, Pioneer HD radio, Uniden CB Radio, K&N Air filter, BAMF Sliders w/kickout, Relentless Aluminum IFS Skid, 24 LED light bar, custom/homebuilt expedition style bed rack and basket combo, and Body Armor rear plate bumper.
    I have literally no experience with suspension and stuff, but my truck had a bent knuckle that stumped several mechanics at the toyota dealership for a while. The hadn't noticed that that was the problem for a few days and thought it might be the frame that was bent before they figured it out.
    Sooo maybe thats it?
  6. Jan 11, 2013 at 2:35 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    here is one that's effed
  7. Jan 11, 2013 at 2:37 PM
    4lo
    El Campo, TX
    2017 TRD Sport
    some stuff
    Ok. I'm lookin everything over. Alignment tabs match the pass side so something's bent.
  8. Jan 11, 2013 at 2:39 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    yeah probably a spindle then. That sucks.
  9. Jan 11, 2013 at 2:40 PM
    MonkeyProof
    SoCal- SGV
    Even tho the tabs are good the cams could have moved..if everything appears to be OK visually then the next step would be an alignment and go from there
  10. Jan 11, 2013 at 2:49 PM
    4lo
    El Campo, TX
    2017 TRD Sport
    some stuff
    That's what I thought originally but can the spindle bend, being cast and all? Could be worse if that's all it is.
  11. Jan 11, 2013 at 3:06 PM
    4lo
    El Campo, TX
    2017 TRD Sport
    some stuff
    Yep. Bent. Damn. Flat screen into garage for playoffs. Thank y'all. Go broncos.
  12. Jan 11, 2013 at 4:49 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I'm not buying a bent spindle @3 mph into a concrete block.
    Either the alignment is just screwed or you were going faster and hit harder than 3 MPH.
  13. Jan 11, 2013 at 5:14 PM
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    The knuckle can bend fairly easy. Measure the distance between the top inner sidewall and the long skinny part of the knuckle. Do this on the passenger and driver side and compare.
  14. Jan 11, 2013 at 5:42 PM
    4lo
    El Campo, TX
    2017 TRD Sport
    some stuff
    Where spindle meets the boot on the uca measured to the radius on the flare is 14" on the driver and 13 1/2" on the pass. The bisnatch is bent.
    I doubt I was even going 3 mph. I was in a parking lot loading tools from one of my guys truck, the way he was backed to me i didnt see what was past his hood, kinda side by side but 45 degrees. I literally rolled out and hit an old light pillar about 6 feet from where I was parked. Didn't even see the effer and not to proud bout it :eek:.
    Go Broncos.
  15. Jan 11, 2013 at 5:55 PM
    nucktaco
    nucktaco Well-Known Member
    Scott
    south surrey, bc
    08 Double Cab TRD Sport
    satoshi mod, sliders, tinted tails/3rd brake, 3" lift,
    why not take to an alignment shop and have them take a look?
  16. Jan 11, 2013 at 6:08 PM
    4lo
    El Campo, TX
    2017 TRD Sport
    some stuff
    I'm pretty confident that its a bent spindle. Gonna wait on the alignment if they can't get to specs I'm still out $80 without any more beta.
    I'm gonna pull the spindle tonight and compare it to one in stock at Toyota tomorrow. Then I'll bend over and accept the price, squeal, cry, purchase, install. And continue to cry, I gotta go oem on this, used is so not cool cuz these bastards are pretty fragile.
  17. Jan 11, 2013 at 6:13 PM
    4lo
    El Campo, TX
    2017 TRD Sport
    some stuff
    Agree and called a few in town. All agreed that its really not possible to have the alignment out so bad that the tire hits. Plus I'd have to tow her....
  18. Jan 11, 2013 at 6:22 PM
    Anteupp
    Anteupp Mega Member
    i agree, somethings wrong here. Maybe a bad spindle from the start. Ive run stock spindles on my long travel kit for over a year(they are gusseted now) and not once has anything bent, Ive hit ledges bigger than curbs going 45+ some food for thought i guess.
  19. Jan 11, 2013 at 6:25 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    Surly more than 3mph. Sorry but if that bent it than Toyota is junk. I just know that it should have went over a center block at 3 mph. Really don't think a spindle would bent that easy. Maybe tire rod?
  20. Jan 11, 2013 at 6:42 PM
    4lo
    El Campo, TX
    2017 TRD Sport
    some stuff
    Ok. Let me define "concrete block" my bad. It was a block of concrete used as pillar for a light back in the day, secure to the earth-not movin for a tank-kinda block that could stop transformers and even bounce a tacoma. Not an 8x12 oversized brick. Like drivin into an invisible wall kinda concrete block.
