Help! I cannot figure out what the rubbing/humming noise from my front end is!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gen2taco, Nov 17, 2012.
  1. Nov 18, 2012 at 1:59 PM
    Tacoma Mike
    Southern Maine
    Front hub bearing Nick. If the install was correct on the right side replace the left. The noise vibrates and travels through the front and can be hard to diag which side it is.. Jack the front of the truck up and spin both front wheels with a finger on the coil spring. I bet the left side will feel rough and vibrate your finger.
  2. Nov 18, 2012 at 5:32 PM
    gen2taco
    gen2taco [OP] Member
    Nick
    Portland, Maine
    09 Taco
    Stock
    Thank you for the advice. I will try this tomorrow after work!
  3. Nov 18, 2012 at 5:41 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i would think that the turning to the right and it stopping would point to the passenger side front wheel bearing. same thing happening on mine when i turn to the left and all indications seem to be the drivers side. just havent replaced mine yet.
  4. Nov 18, 2012 at 6:22 PM
    Tacoma Mike
    Southern Maine
    It all depends on which half of the bearing is bad. There are two sets of rollers in the bearing and depending on which is bad, the inner or outer, can cause a different result. Been through this before and it can be a pita to get the correct side. I'm hard of hearing so I have to use more than just sound to confirm. That's why he needs to double check. With a bearing that bad he should feel it.
    I also take one of the young kids with me on a road test if necessary.
  5. Nov 18, 2012 at 7:49 PM
    JayLeah
    JayLeah Well-Known Member
    Jessica
    New Orleans
    08 SR5
    Mine does this too. But unless you know what your listening for, it's very suttle. it does it when I'm pulling in my drive way which is on a slight incline, when I'm slowing turning and sometimes just going through the gears. Park to drive, drive to neutral, neutral to reverse. It's very weird.
  6. Nov 18, 2012 at 9:35 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    yep, sounds exactly like the noise I had
  7. Nov 18, 2012 at 9:40 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    My 2012 does this also.. But my noise could possibly be my tires, bc I did my lift and tires at the same time..
    I know its not my Diff. bearing though. I went through that with my 07 Taco.
    I hope you figure it out.
  8. Nov 19, 2012 at 3:24 PM
    gen2taco
    Nick
    Portland, Maine
    09 Taco
    Stock
    After work today, I jacked up the front end, and tried what you asked. The left side is definitely rougher than the right side(the one I replaced). I could feel it vibrate through the coil as well. I never thought to check the left side given the symptom I was seeing (video), LOL I learned my lesson. I think you figured it out! Thanks for the advice. I will change it out on my day off next Monday, and post back results! If anyone is wondering I do not daily drive the truck until there is snow, so I won't be making my daily 50 mile commute on a bad bearing.
    Thanks to everyone else for their reply's as well.:D
  9. Nov 19, 2012 at 6:46 PM
    Tacoma Mike
    Southern Maine
    I think you got a handle on it.
    Let us know how it goes.
    Stop by the shop sometime and introduce yourself.
  10. Nov 20, 2012 at 3:38 AM
    gen2taco
    Nick
    Portland, Maine
    09 Taco
    Stock
    Where is your shop?
  11. Nov 20, 2012 at 9:17 AM
    K3tsurui
    K3tsurui Well-Known Member
    Ricky
    Upstate NY
    In case it is not the wheel bearing, here is something else that might help...
    I had a similar problem on a different vehicle (not a Tacoma). It took forever and a day to find it. The one thing that you said that caught my attention was that the "noise goes away when you turn". For me, the problem turned out to be the rear differential bearing. Not sure how you would check this but it wasn't all that hard to replace and the part was relatively inexpensive.
  12. Nov 26, 2012 at 11:41 AM
    gen2taco
    Nick
    Portland, Maine
    09 Taco
    Stock
    The problem is fixed! It was the left front wheel bearing. I just finished installing it, and took it for a test ride. It smooth as can be! Thank you for all the help!
  13. Nov 26, 2012 at 12:52 PM
    Tacoma Mike
    Southern Maine
    Good for u. Just remember that trick for the future. :yay:
  14. Nov 26, 2012 at 4:45 PM
    gen2taco
    Nick
    Portland, Maine
    09 Taco
    Stock
    Will do!
  15. Jan 5, 2013 at 3:15 PM
    #35
    Tevia74
    Tevia74 09, 2.7, 4x4, Manual, Access Cab
    Tom
    Albuquerque
    09 4x4 Taco
    Actually joined this site in hopes of figuring out what this was on my truck. The only diference is that mine is really only there when taking a long, sweeping left turn at speeds over 55ish, but then it sounds much like what was in your video. Have you figured it out yet? Can you feel it as well... not necessarily in the steering wheel but the chassis ? If you have had any luck please let me know. I was just about to go down the same wild goose hunt road of replace and pray.
  16. Jan 6, 2013 at 7:44 AM
    #36
    gen2taco
    Nick
    Portland, Maine
    09 Taco
    Stock
    I was able to figure it out. It was the opposite wheel bearing I had replaced. Tacoma Mike gave me the advise that help me find it. I jacked up the front end, and spun the wheel with my finger on the spring. I could feel the vibration in the spring. You may want to do the same, and also check your rear wheels.
  17. Feb 24, 2013 at 6:26 PM
    #37
    baseballfan5566
    baseballfan5566 Well-Known Member
    I have the same problem, I feel like what you described is exactly what I am hearing. At least I know its nothing major.
    Thanks
  18. Jul 17, 2020 at 4:49 PM
    #38
    MossyOak
    MossyOak New Member
    2009 Tacoma Prerunner
    Im having this problem right now. Just had it diagnosed. While driving when you hear the humming jerk the steering wheel slightly. If sound changes, most likely wheel bearings. Jack up front end. One side at a time. Have some one spin wheel as you listen with stethoscope to bearing casing underneath. You should hear clatter in the bad wheel. Im having mine replaced right now. One is bad but I'm replacing both. Will be approx $800 to fix. Not bad for a job in the middle of no where.
