Help. I can't fill gas tank.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Paulie, Aug 31, 2011.
  1. Aug 31, 2011 at 11:37 AM
    Paulie
    Paulie [OP] Well-Known Member
    Paulie
    USA
    Tacoma
    The gas pump shuts off every 1/10 gallon. The truck is an '02 w/ 49k miles. It has never been off roaded so there is no mud blocking tank breather. All vacuum lines are hooked up. I would be thankfull if any knows how to fix this.
  2. Aug 31, 2011 at 11:44 AM
    Sport11
    Sport11 Well-Known Member
    Kingsport, TN
    Dodge Ram 1500
    Try a new gas station :notsure: I have had to move to another pump before over some similar experience.
  3. Aug 31, 2011 at 11:49 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Mine does that sometimes. If I hold the nozzle so it's only 3/4 as far as it will go into the tank then it fixes it.
  4. Aug 31, 2011 at 11:51 AM
    okboatie1
    okboatie1 Well-Known Member
    Darrell
    Chula Vista, CA.
    03 PreRunner TRD SR5 DCSB
    OME 881's w/Dakar's, Deckplate mod, Debadged, door chime mod, 12V outlets always on,
    Have problems all the time on base. Just try another pump/station before you start looking at your ride IMHO...Good luck
  5. Aug 31, 2011 at 12:04 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    yeah, it's a pump issue, not a truck issue!
    Sometimes I have to hold the handle down for the entire tank, instead of flipping the little lever that holds the handle down, because the auto shut-off keeps tripping.
    Just fiddle with the position of the hose (pull it out a little bit, or push it in a little further), or just hold the handle. Or go to a different pump.
    jackn7 likes this.
  6. Aug 31, 2011 at 6:22 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
  7. Aug 31, 2011 at 6:25 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Sometimes I have to hold the nozzle upside down at some stations... :confused:
  8. Aug 31, 2011 at 6:28 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    X1
  9. Aug 31, 2011 at 6:32 PM
    Gieser
    Gieser Official Flatlander
    MB, Canada
    06 tundra yamaha edition
    scion Head Unit and magnaflow muffler...so far
    my moms camry did this but it was alot worse. it ended up being the charcol canister. something to do with the fuel filler neck. maybe the same thing?
  10. Aug 31, 2011 at 6:43 PM
    98tacoma27
    Ben
    Not Beech Creek
    ^those^
    The fill tube design cuts off the venturi (see below)
  11. Aug 31, 2011 at 6:47 PM
    Urban Redneck
    Urban Redneck Well-Known Member
    2004 3.4L V6
    Same here. It sucks that you can't walk away from it, but this still works. It's only at some stations that it happens, tho.
  12. Sep 1, 2011 at 4:38 PM
    Paulie
    Paulie
    USA
    Tacoma
    I'm going to chect out the canister. It's a truck issue. It worked fine then one day was unable to fill tank
  13. Jun 6, 2014 at 3:26 PM
    REvans2001
    REvans2001 New Member
    Russell
    San Marcos, CA
    2002 Taco SR5
    I had this problem after Mr. GoodWrench did oil change and air filter on my 2002 Taco. Turned out that the mech pinched a hose under the air filter cover. Took off the cover, moved the hose and replaced the cover: fixed!
    Good luck!
  14. Nov 9, 2017 at 7:25 AM
    joeh8014
    joeh8014 New Member
    Mine did the same thing. A spider got into the fuel filler neck vent line and made a web. It completely blocked the air flow. You can either clean the vent line or purchase a new filler neck. You can find the filler neck online for less than $100. Cheap fix and easy to do.
