Help! I got bigger tires and added a leveling kit!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crystalqng23, Jun 7, 2013.
  1. Jun 7, 2013 at 9:33 AM
    Crystalqng23
    Crystalqng23 [OP] Member
    Crystal
    Norwalk
    2012 Toyota Tacoma
    2" Leveling Kit
    A few months ago I decided to get bigger A/T tires and 17" wheels along with a 3" leveling kit. For about 2 months car just a tad rougher on the freeways,which I expected. Now its riding really rough. Going pass 60 mph my trucks shakes and my steerling wheel as well. I noticed a couple of weights that came off my drive on my driveway. So I brought my car in for service and they re-balance my tires. It drove fine for a few days. Now this morning I was on my way to work and my truck is doing the same thing. Is this normal? Any solutions?
  2. Jun 7, 2013 at 9:36 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Where are you feeling the shaking? Is it in the steering wheel, do you feel it by your feet, or is it more in your butt? Is the roughness dependent on speed?
  3. Jun 7, 2013 at 9:36 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    You check the weights again?
  4. Jun 7, 2013 at 9:36 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    What kind of 3 inch lift? spacer, suspension, body?
  5. Jun 7, 2013 at 9:37 AM
    Lazylegs
    Lazylegs Well-Known Member
    Craig
    Southern Maryland, USA
    2011 Red Toyota AC Sold
    Tint (35%), a must. Step bars, Bull bar, Bull lights,4x4 light mod, Flip down 10" DVD player, De badged, Color match front emblem, color matched bumpers., black out tails, Cobra cb, Flashlight mod,bed-light mod,
    A leveling kit or a lift kit? A leveling kit is not going to affect your steering.
  6. Jun 7, 2013 at 9:37 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Was it road force balanced?
    What rims, and what are the specs?
    Some rims may be hub or lug centric and require small spacers to make them work well I THINK......im not a rim guru, but I swear I've heard those things before.
    Also, check ur tires for any blisters/buldges/our of roundness.
    The shop shoulda noticed any imperfections, but ya never know.
  7. Jun 7, 2013 at 9:38 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    A leveling kit lifts the front, so they are both lifts
  8. Jun 7, 2013 at 9:39 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    This. Make sure they were balanced properly. Road force is pretty much the only way with larger tires.
  9. Jun 7, 2013 at 9:39 AM
    brian
    Elizabeth City, NC
    Sorry bud, same thing. It is going to affect your steering.
  10. Jun 7, 2013 at 9:41 AM
    Specalt
    Specalt Well-Known Member
    Phoenix
    2001 TRD 4x4
    3" for leveling is a lot. It sounds more like a spacer lift. Did you get an alignemtn done?
    This could be wearing your wheels causing your wheel to become unbalanced and the wheel throwing weights.
  11. Jun 7, 2013 at 9:56 AM
    Crystalqng23
    Crystal
    Norwalk
    2012 Toyota Tacoma
    2" Leveling Kit
    I got pro comp wheels. I did a front leveling kit only. My steering wheel shakes and so does my car. I plan on taking my car in to the same guys again but I don't know if even know what to do.
  12. Jun 7, 2013 at 9:58 AM
    brian
    Elizabeth City, NC
    Steering wheel shake is typically an out of balance issue.
    The folks there aren't doing a good job balancing your tires. Find another shop, make sure they do 'road force balancing'. Its a special machine made by Hunter, not every shop has it. Don't pay too much because I've seen shops do ripoffs for the use of their machine. They shouldn't charge any more than normal for it.
  13. Jun 7, 2013 at 10:01 AM
    brian
    Elizabeth City, NC
  14. Jun 7, 2013 at 10:17 AM
    Crystalqng23
    Crystal
    Norwalk
    2012 Toyota Tacoma
    2" Leveling Kit
    Typically how much is to re-balance?
  15. Jun 7, 2013 at 10:22 AM
    ToyTacosRule
    ToyTacosRule Well-Known Member
    Dane
    Texas
    4x4
    If you did the level kit and did not get your front end aligned then your tires will wear more most likely on the inside which after a little while of driving will make the tires not balanced.
    Bottom line: if you did not get a front end alignment, do so or you will keep having this problem no matter how the tire is balanced.
  16. Jun 7, 2013 at 10:26 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Lmao......good call. I assumed the shop did this, but ya never know. Some shops can be shady
  17. Jun 7, 2013 at 10:26 AM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    Hub rings?
  18. Jun 7, 2013 at 10:29 AM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    $10 a tire
  19. Jun 7, 2013 at 10:29 AM
    aubi1414
    Justin
    Pensacola, FL
    ^This :eek:
  20. Jun 7, 2013 at 10:57 AM
    Crystalqng23
    Crystal
    Norwalk
    2012 Toyota Tacoma
    2" Leveling Kit
    I did have a alignment.
