Help!!! I got excited and... Well...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by techride, Aug 25, 2015.
  1. Aug 25, 2015 at 2:08 AM
    techride
    techride [OP] Weekend Warrior
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    Bilstein/Icon 2" suspension lift with wheelers 5 leaf springs, 7-pin relocate through bumper, bfg KO2s, redline hood struts, immryo mirror relocation, stubby antenna, dipped emblem, heated mirrors, Jason trek cap, led fogs, debadged
    SO! I'm a frequently lurker, occasional poster and totally obsessed with my truck like the rest of us. I'm calling upon the suspension gurus of TW to help me out here. I own a 2014 DCLB and I put lots of miles on my truck. Up until recently I've been mostly highway commuting with my truck during the week and bombing/shuttling nasty FSRs and camping with my better half on weekends. When I bought the truck (and before I discovered TW) I was talked into a spacer lift by a local tire guy that typically works on full size trucks. I was unaware of the shortfalls and dangers these lifts can pose, and only after experiencing it myself did I realize how wrong he was. I recently bought a dual sport bike for commuting and now the truck sees 50/50 on/off road driving. I have a camper shell and carry 200-300lbs of cargo when I go camping, plus I tow dirt bikes on a trailer regularly. I've always found the stock springs spongy and since the 2" block went in it's been downright squirrely. I was doing research on lift upgrades so I could ditch the stupid spacers, and although I dreamt about an icon stage 3 lift, my budget really only allowed for basic 5100's all around with OME 885 coils up front and cheap AAL in the rear.... Maybe a deaver 2" leaf pack of I stretched it.
    Here lies my problem.
    I found a screaming deal on some Icon non-reservoir 0-2.5" rear shocks and I jumped on it, not thinking about icon's digressive valving and now I'm wondering how my truck will ride if I'm to complete my lift kit with anything other than Icon front suspension. Did I just shoot myself in the foot? Am I now stuck saving for and forking out for a full icon kit or would these with an icon progressive 1.5" AAL pair up ok with something a little more affordable? Say, my original plan of 5100's with 885's? I appreciate your input! :D
    -Stu
  2. Aug 25, 2015 at 4:29 AM
    2012SilverSport
    2012SilverSport Well-Known Member
    Guam
    2012 Silver TRD Sport Double Cab
    CS Jumpers LED's throughout the cab and marker/DTRL's weather techs/seat covers. Head unit Pioneer AVHX5500BHS, Speakers, Front, Polk Audio DXi 6500 component, rear Polk Audio DXi 650s Subwoofer Sound Ordinance B-8PS, Amplifier Alpine KTP 445U. Front ICON extended travel 2.5 remote resi, Camburg UCA's. Rear ICON 2.0 remote res rear. Wheelers 3 leaf HD progressive AAL,
    You can still do OME or 885's up front but I would not recommend it. You will likely go to ICON front as well and may get a push pull type of scenario with your suspension due to different dampening/rebound rates if you go with something other than ICON. Think of it this way, ICON KING FOX CAMBURG as well as OME etc are designed to work together. If you look around and contact Wheelers/TOYTEC/DownSouth motorsports you can find a good deal on non-resi fronts. You will be glad that you bought a "matched" set-up.
  3. Aug 25, 2015 at 4:33 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I have icons all around and Dakars in the rear. Load it up!
  4. Aug 25, 2015 at 4:40 AM
    BloodThinnerz
    BloodThinnerz Well-Known Member
    Alberta
    2015 MGM DCLB
    TRD Cup Holders
  5. Aug 25, 2015 at 5:24 AM
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    You can get icon front coil overs for a little over a grand so I guess start saving!
  6. Aug 25, 2015 at 5:52 AM
    ekron
    ekron Well-Known Member
    Emily
    Long Island, New York
    2014 Tacoma 4x4
    Toytec/Boss Coilovers, Icon 2.0 with AAL in the rear. General Grabber A/T 2 ARB front bumper
    I have a mismatched set. Same rear shocks you just bought along with an AAL, and Toytec/Boss coilovers in the front. It rides alright and I've had them on for the better half of a year. Took them offroad and have no complaints. I will eventually end up buying their coilovers for the front just to have a full set
  7. Aug 25, 2015 at 6:31 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Get some Icons for up front. Black Friday sales are your friend.
  8. Aug 25, 2015 at 9:21 AM
    techride
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    I forgot about Black Friday! That may be my calling to complete my setup... I think I'm going to save my lift install until I can ditch all the spacers at once. Ideally I'd get some entry level non-resi fronts to complete the set... 1200 will take a while to save though.
  9. Aug 28, 2015 at 12:20 AM
    techride
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    The new bilstein 6112's look pretty appealing too, and they claim they are set up with digressive valving as well. For half the price of an icon front end, it sounds awfully tempting...
  10. Aug 28, 2015 at 12:47 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    If you are on a budget then get the bilstein shocks! If you want a shock that can be rebuilt then go for the icons.
  11. Aug 28, 2015 at 3:23 AM
    2012SilverSport
    Guam
    Billies are good but there is a reason they are half the price.
