HELP!! I KNOW NOTHING ABOUT CAR AUDIO
Discussion in 'Audio & Video' started by Marioso, Feb 26, 2011.
  1. Feb 26, 2011 at 9:23 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    I believe it is used to measure electrical resistance
  2. Feb 26, 2011 at 9:24 PM
    Marioso
    Marioso [OP] Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    so i need ohm 4 or ohm 2?
  3. Feb 26, 2011 at 9:27 PM
    tacobell007
    Drew
    Western MA
    once you find a sub you like. You need to find out a few things about the sub.
    1. What it is rated RMS (constant power)
    2. ohm, 4 ohm sub to a 4 ohm stable amp (pretty much all amps are stable at 4 ohms)
    3. if it is only for a sub, get a mono block. for subs, get a 2 channel. subs and speakers, 4 or more channel
  4. Feb 26, 2011 at 9:30 PM
    Marioso
    San diego Ca
    whats been 2 way to 4 way?
  5. Feb 26, 2011 at 9:30 PM
    Marioso
    San diego Ca
    so the amp has to match the subwoofers constant power
  6. Feb 26, 2011 at 9:32 PM
    tacobell007
    Drew
    Western MA
    a 2 channel amp. has 2 hook up on it (2 positive terminals, 2 negative terminals). 4 channel amp has 4 hook up on it (4 positive terminals, 4 negative terminals) Also, a 2 channel amp is most likely smaller than a 4 channel amp will be.
  7. Feb 26, 2011 at 9:34 PM
    tacobell007
    Drew
    Western MA
    The constant power on the amp can be lower than the constant power the sub can handle, but I would not advise getting an amp that will have more constant power than what the sub can handle constantly
  8. Feb 26, 2011 at 9:35 PM
    flyby08
    flyby08 Well-Known Member
    san francisco
    2008 TRD sport 4x4 short bed
    TRD Catback exhaust, Topdeck tonnaeu cover, locking gas cap, all weather floor mats, Pop-n-lock tailgate, painted black rims, volant CAI with RAM air scoop, 10" MTX thunder sub with 2ch amp, Alpine SPS-609 and 600, Pioneer AVHP-3200BT HU
    ohms is the measure of resistance of the current. 4 ohms is pretty normal, the higher number the higher the resistance. This becomes important when when your are setting up ur sub and amp because cuz you and mess with switchng from 4 to 2 ohms to increase the power to your subs, but it can damage your sub. i have a 3200bt and its a great HU and i ran it with the stock speakers for awhile it is work alright but i know what your are talking about.
    like others have said any shallow mount sub from mtx, alpine, kenwood should work fine. I run one 10 mtx thunder sub, and i like it. But i have to say if you want to keep the stock speakers and have two 10's you might find that the sub will overpower the speakers not giving you the quality that you are looking for
  9. Feb 26, 2011 at 9:37 PM
    Marioso
    San diego Ca
    im fine w that for now. i just dont want thebass right now to blow my speakers
  10. Feb 26, 2011 at 9:38 PM
    Marioso
    San diego Ca
    Product Description
    KICKER introduced a true high-performance subwoofer with a reduced mounting depth a few years back, and it was met with immediate success. Who wouldn't want a subwoofer that pounds insanely from the slimmest locations The next generation of KICKER CompVT Subwoofer slides into door panels and other tight fits. Precise KICKER engineering allows the CompVT to pound with limited space. A special four-layer voice coil provides the CompVT the ability to work with serious amounts of power without the bulk. The woofer's stiff, injection-molded, modified-spoke cone is shaped to provide maximum excursion from a slender basket, allowing the ideal amount of flex for better strength and durability.
    Features:
    Steel clearance adapter plate replaces part of enclosure wall depth to further lessen depth High-temp coil wire Slender, strong steel basket with coil-cooling perimeter venting Durable Spiralead tinsel leads Tough double-stitched surround Special spring-loaded binding posts for minimizing depth IMPEDANCE (Ohms) - 4 DVC POWER WATTS (peak/RMS) - 800/400 SENSITIVITY (dB 1w/1m) - 86.8
    i dont see anything about wattage
  11. Feb 26, 2011 at 9:39 PM
    Marioso
    San diego Ca
    how much is that combo at best buy? u got a link
  12. Feb 26, 2011 at 9:42 PM
    Marioso
    San diego Ca
  13. Feb 26, 2011 at 9:42 PM
    flyby08
    san francisco
    it says it at the end, 800/400 peak and RMS so you can get at a 400W or less mono ch amp or a 2 ch and bridge it (that what i did) and you should have enough to power the sub.
  14. Feb 26, 2011 at 9:43 PM
    Marioso
    San diego Ca
    ok so say i go with that sub, what amp shoul di look for
  15. Feb 26, 2011 at 9:47 PM
    #35
    Marioso
    San diego Ca
    amps are pricey. haha so i can explain the deal i got from a car audio place. 150 for the box, 80 for each sub, 150 for amp. hows that sound? all rockford products
  16. Feb 26, 2011 at 9:51 PM
    #36
    flyby08
    san francisco
    have you heard it yet, that is really the determining factor of whether its worth it or not. If it sounds like garbage then it not worth. but if you like it, that is not a bad price at all
  17. Feb 27, 2011 at 6:22 AM
    #37
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    x2....google is some amazing shit lol. Your on the right track. if your powering one sub rated at 500 rms get a one channel amp thats got around 500 watts or more and adjust the amp untill you like the volume its at. ohms is the measure of resistance. ill try to find a wiring diagram that explains ohms in car audio for you
  18. Feb 27, 2011 at 6:32 AM
    #38
    xwillx93
    xwillx93 Well-Known Member
    Will
    Stuart, FL
    09 Tacoma
    MBRP "Cool Duals" dual side swept exhaust, Volant Intake, Blacked Out Tail lights, Touchscreen Kenwood DDx616 with a 10" Kicker CVR in a custom Box, 2 Kicker Comp 6" Speakers, Removed front and rear mud flaps, Weathertech Floormats, Kobalt Slim Toolbox, Chevrolet Air compressor
    I have a Double-Din Kenwood ddx616 touchscreen that i already heard improvement in. Then i purchased a Kicker (1200) watts with a 1500 watt sony amp and it sounds great! custom made a box to fit behin my bench and im looking into upgrading my speakers soon and another sub! good luck! here's some pics that might help
  19. Feb 27, 2011 at 7:48 AM
    #39
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    i love the way it sounds, it is nice and clean sounding and hits hard for only being a 10"
    i think the sub/box was like 200 and i dont remember how much the amp was
  20. Feb 27, 2011 at 9:49 AM
    #40
    ThreeMan
    ThreeMan Opinions Vary...
    Oswego, NY
    08 4x4 V6 TRD DCLB
    King Remote Resi Suspension - Total Chaos UCAs - Full Katzkin Leather - Leer Camper Shell - Custom Projector Halo Headlights - HID Fogs - Eagle Eye LED tail lights - Rigid Industries LED Light Bar Mounted in Bumper - Wade In-channel Vent Visors - K&N Filter - 20% on the fronts - Dakar Progressive Leafs - Fuel Beast Wheels wrapped in Hankook Dynapro ATMs - 4 Tie Down Mod - Pop N Lock - Billet Grille - Weathertech Mats - LED Map and Dome Lights - Optima Yellow Top - Redline Elite Hood Struts - Tunes: Eclipse 7100 HU - Eclipse IPC-106 Interface - Audison LRX 5.1K - Hertz Mille MLK2 Components - JL 13TW5 - JL cables and wires - Fully Deadened with SDS products - Metra dash kit - Custom Sub Box and Amp Rack - Still Under Construction.
