HELP! I need a straight answer about building a wall.
Discussion in 'Garage / Workshop' started by comiesutra, Feb 22, 2013.
  1. Feb 22, 2013 at 4:05 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    This. Doesnt mean i will use non treated wood on slabs though. Straight from simpson strong tie website-
    Are these alternative products more corrosive than CCA-C?
    Testing has indicated that some of the alternative products are more corrosive to steel and some protective coatings applied over steel than Chromated Copper Arsenate (CCA-C). Contact the treated wood chemical supplier for more information and see te Preservative Treated Wood Technical Bulletin (PDF).
  2. Feb 22, 2013 at 4:08 PM
    evanmb31
    evan
    connecticut
    09 trd off road
  3. Feb 22, 2013 at 4:10 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    until they form humps in your wallz
    silly carpenters :D
  4. Feb 22, 2013 at 4:12 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Crowning studs is proper practice
  5. Feb 22, 2013 at 4:12 PM
    comiesutra
    comiesutra [OP] Well-Known Member
    Greenwood, IN
    '10 4X4 Silver AC SR5 Manual
    MonsterKnobs.com shift knob, Sony MEX-BT3900u
  6. Feb 22, 2013 at 4:13 PM
    OZ-T
    Peter North
    British Columbia
    Sill gasket
  7. Feb 22, 2013 at 4:15 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Vapor barrier... although if you don't know how the house was built, then the gasket isn't a bad idea. I'd still use PT for the sill though, call it habit.
  8. Feb 22, 2013 at 4:15 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    You build crazy custom homes, i would be crowning studs and making sure everything is perfect if i was doing this. I do production framing, the faster the better, i never crown studs. If im framing a wall and the stud is crowned real bad i wont use it.
  9. Feb 22, 2013 at 4:16 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Sill seal and PT
  10. Feb 22, 2013 at 4:17 PM
    OZ-T
    Peter North
    British Columbia
    vapour
    and it doesn't matter , sill gasket under and non treated lumber in contact with concrete
  11. Feb 22, 2013 at 4:18 PM
    OZ-T
    Peter North
    British Columbia
    Takes the same amount of time , when you pick up the stud sight it and assemble the wall crown up
  12. Feb 22, 2013 at 4:19 PM
    OZ-T
    Peter North
    British Columbia
    Not a fan
  13. Feb 22, 2013 at 4:19 PM
    comiesutra
    Greenwood, IN
    Step away for dinner and I get a flood of answers. After reading all the answers here's my plan.
    Sill gasket, double top as the floor joists are 20 on center and the wall will be 16, snug but no pressure on the joists especially on the exterior wall, tapcons, framing nails, measure twice and cut once.
  14. Feb 22, 2013 at 4:20 PM
    XXXX
    sKiP
    05 Prius
    this
    even though no one does it. skills diminishing due to lack of properly trained union labour :D
  15. Feb 22, 2013 at 4:21 PM
    #35
    OZ-T
    Peter North
    British Columbia
    :thumbsup:
  16. Feb 22, 2013 at 4:24 PM
    #36
    evanmb31
    evan
    connecticut
    09 trd off road
    .... Lol lets not get into that
  17. Feb 22, 2013 at 4:25 PM
    #37
    XXXX
    sKiP
    05 Prius
  18. Feb 22, 2013 at 4:28 PM
    #38
    Pugga
    Massachusetts
    I don't know many people who use union labor for a residential project... :rolleyes:
  19. Feb 22, 2013 at 4:29 PM
    #39
    OZ-T
    Peter North
    British Columbia
    labour
  20. Feb 22, 2013 at 4:30 PM
    #40
    Pugga
    Massachusetts
    I was referring to US unions, so labor. You can add your fancy extra U for Canadian labour :rolleyes:
