Help! I need input on my first lift!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by StaldineJ, Aug 28, 2010.
  1. Aug 28, 2010 at 3:32 PM
    StaldineJ
    StaldineJ [OP] Member
    Jon
    Moscow, ID
    99 sr5 2.7L 5 speed
    ICON Rear AAL Bilstein 5100 shocks Repainted to a silvery green Deck plate Clarion ProAudio Receiver Bedliner - Al's Liner Leer 100R Topper Rocker panels sprayed with Als's liner
    I am looking into lifting my 99 x-cab 4x4 sr5 2.7 liter, not a lot, just a little. My wife always has teased about it being a "cute little truck", until the day the factory bug guard was broken and taken off - now she thinks it looks like a 2wd tacoma :mad:. No offense to you guys out there with the non PreRunner 2wd five luggers, just not my style.
    I'm a college kid, almost done - so money isn't always readily available. Recently the Tacoma came out of gear (not pointing fingers as to who the last person driving it was ;)) hit a dumpster and scraped up the whole passenger side. We got $3800 in settlement with the insurance company. My better half and I agreed that I'd use half the settlement to fix my beloved little tacoma up the way I'd like to, and half to pay back some unsubsidized loans racking up interest. I did the body work myself, it came out A LOT better than I thought, got a hookup for the paint, and basically have a fair amount to do as I see fit... including a spray in bedliner.
    I scored a set of Toytec 2" spacers for dirt cheap, and am upgrading to Bilsteins for the front shocks/struts. I'm also thinking about getting the ICON add-a-leaf mini spring packs for the back. That should level the truck out front to back, and I'm hoping increase the payload capacity a little bit. The rear shocks were replaced about a year ago - cheap-o KYB CarQuest shocks, would I need extended shocks for the 1.5" lift in the rear? Or could I get away with standard length Bilsteins?
    Along those lines, will I need the front differential drop spacers to accomodate the 2" front lift?
    Thanks for your input!
  2. Aug 28, 2010 at 4:04 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    what..prerunners are 2wd...anyway you'll be fine in back without extending the brake lines
  3. Aug 28, 2010 at 5:48 PM
    StaldineJ
    Jon
    Moscow, ID
    99 sr5 2.7L 5 speed
    Lol, Pre-Runners are all good... it's those ass-dragging five lugged low rider trucks I'm not a fan of... Actually I'm thinking my next truck might be a double cab Pre-Runner.
    extended brake lines :eek: I hadn't even thought of that!!!
    The whole process is a little more complicated than I thought at first. It'll be worth it in the end though, I hope. I'll keep this little truck until the wheels fall off, I figure it should make it to 200 - 250k no problem, which makes the truck middle aged.
  4. Aug 28, 2010 at 6:09 PM
    CopDoctor
    08 335i
    or sorry i mis-read your post..saw extended and jumped to a conclusion. you don't need extended shocks either, only if you plan on flexing the hell out of your rig
