HELP!!! I need to know what to do for the sec air filter...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lentsnh, Jan 23, 2009.
  1. Jan 23, 2009 at 2:15 PM
    Lentsnh
    Lentsnh [OP] Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Right as we speak i am taki9ng out he secondary air filter. and i need help on how far to drill and NOT screw up my airbox.
    V6 4.0L
  2. Jan 23, 2009 at 2:16 PM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    why didn't you have me over and we could have done ours together....
  3. Jan 23, 2009 at 2:47 PM
    FlawedXJ
    Paul
    NorAla
    bump for someone that knows, and did what I say to do work?
  4. Jan 23, 2009 at 6:11 PM
    Snyperx
    Snyperx Seniore Marcos
    I basically just drilled out the plastic rivets. Don't press down hard and you won't put the drill bit through the air box side wall.
  5. Jan 23, 2009 at 6:42 PM
    Lentsnh
    Just let it drill it self? like very little pressure? and do i go in until the drill falls out of the hole
  6. Jan 23, 2009 at 6:47 PM
    Snyperx
    I just kind would put light pressure on the drill, drill a bit, then check where I am at. I know I started with a small drill bit to get a pilot hole going, then used bigger bits until it was the size of a rivet hole. I did the pilot hole so the drill wouldn't start wandering around. I think the largest bit used was 1/8? Can't remember 100%.
  7. Jan 23, 2009 at 6:49 PM
    Lentsnh
    i was using the 9/64 until my dad saw what i was doing..
  8. Jan 23, 2009 at 7:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Keep it in.
  9. Jan 23, 2009 at 7:14 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    x2...
  10. Jan 23, 2009 at 7:43 PM
    Lentsnh
    will it be bad if i already drilled out two rivets??
  11. Jan 23, 2009 at 7:44 PM
    Lentsnh
    is that my question?
  12. Jan 23, 2009 at 7:47 PM
    1 bad tacoma
    1 bad tacoma Well-Known Member
    rustburg Va
    05 trdsport 4x4
    grapics, 6" fabtech lift, volant intake with ram air scoop, cleared head lights, chrome kit, westin bull bar and steps, custom toyota emblem, throttle body spacer, flomaster 40 series, dick cepeck black and sliver dc1s, trd seat covers, thrid brake light cover, chrome tail lights
    can you explain why to keep it in cause looks like to me that the main filter would catch 99% of the dirt that comes in. mine is gone but thats because i got a cold air intake
  13. Jan 23, 2009 at 7:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes, the Air filter is going to catch everything, but being as there is no gain to removeing the charcaol filter, Why remove it? Haveing a second filter that has no affect on performance just seems like an added benafit.
  14. Jan 23, 2009 at 8:09 PM
    1 bad tacoma
    rustburg Va
    05 trdsport 4x4
    gotcha i was just curious
  15. Jan 23, 2009 at 9:01 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    pull. It wont screw it up. I just pulled like mad and it worked just fine! Good luck!
  16. Jan 23, 2009 at 9:22 PM
    Lentsnh
    is it ok if i already drilled two rivets out?
  17. Jan 23, 2009 at 9:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont see what it would hurt. As long as there are no peices of plastic in there air stream.
  18. Jan 23, 2009 at 9:36 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Just drill about a half inch in. It should pull right out.
    Personally, I still believe that the secondary filter restricts airflow. Blowing 90 psi through it and barely feeling any air on the other side pretty tells me all I need to know.
  19. Jan 23, 2009 at 9:40 PM
    Lentsnh
    well some shavings could have escaped when i was bringing it out.
  20. Jan 23, 2009 at 9:40 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    +1
    But, Chris 4x4 may be right. But the way I look at it, most of the aftermarket set up's like TRD, K&N, URD, Volant and others, replace the whole stock setup all together. So if there was real harm to your vehicle from this Mod, why does Toyota willingly install the TRD intake under warranty. Im sure they know that it's rated as a non Carb approved product. Not too many of us buy these new trucks to go race the BAHA...
    Take it out, leave it in, oh well. Good aftermarket drop in dry filter, no sec filter, should improve your throttle response a bit...
