HELP! I need to reclaim an engine
Discussion in 'General Automotive' started by DanGer, May 10, 2009.
  1. May 10, 2009 at 8:10 AM
    DanGer
    DanGer [OP] Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    My girlfriend told me recently that she rarely changes her oil on her 2001 VW Beetle 2.0 engine. She also told me that last time she just added oil until it was full. I pulled the dipstick today and the oil was black, gritty and thick!
    I am having trouble figuring out which oil weight to put in and whether I can put synthetic in or not. My google searches have come back fruitless since every result i get is the turbo engine
  2. May 10, 2009 at 8:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    See if she still has the owners manual. Otherwise, check with a dealer...
  3. May 10, 2009 at 8:17 AM
    DanGer
    She has the manual but the Kraut organization of that thing is enough to drive someone insane. It doesnt say anything about oil weight, just wear eye protection when changing and fill it a half quart at a time. I will check again
  4. May 10, 2009 at 9:13 AM
    DanGer
    Ok finally found it. Not under maintenance, not under engine, but under tips and advice. It calls for 4.4 qts or 5W-40 or 5W-30. I went and to autozone and got 5 qts. of Penzoil dyno 5W-30 and a filter for $14, not bad!
  5. May 10, 2009 at 12:11 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    I'd recommend doing a drain, fill and flush (drain and fill twice). If it's been that long, you're going to have some thick oil that won't want to come out. Drive it for 50 miles after the first change, and change again.
  6. May 10, 2009 at 12:19 PM
    lawnrevenge
    lawnrevenge Well-Known Member
    Southern California
    08 regular cab 5-lug, automatic
    I second the two oil change method. Put some marvel mystery oil in with the oil and then change it after 50-100 miles. MMO tells you on the bottle how much to add. Also, quit using penzoil. Penzoil is "sticky" and it holds dirt to the walls of the engine. I've rebuilt a few motors and the worst I've seen were run religiously on penzoil and quaker state, oil changed at 3000 miles. Valvoline and Castrol are better. Synthetic is better but costs much more. Something about Pennsylvania oil I guess.
  7. May 10, 2009 at 1:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im gonna "third" what they said ^^^^^^^^^^^
  8. May 10, 2009 at 1:43 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Just cause lawn and chris said it: "Fourth"
  9. May 10, 2009 at 2:27 PM
    DanGer
    It been 7K miles since the last change so it isn't as bad as I expected. I am going to just change it for the drive home (a few hundred miles) then she will be in spain for a month. When she comes home I will change it again.
  10. May 10, 2009 at 2:28 PM
    DanGer
    If the owners manual says nothing about synthetic, how can I determine if I can put it in there?
  11. May 10, 2009 at 2:37 PM
    Ty's Taco
    Ty's Taco Well-Known Member
    Tyler
    Sweet home Alabama
    2009 Prerunner SR5 Sport Pearl Black
    Ask visa or my wife. They both constantly remind me how much I've got left to spend.
    I've heard that they use a type of parafin to keep the oil from breaking down at higher temps and maintain its viscosity.
  12. May 10, 2009 at 3:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can run Synthetic in any engine.
  13. May 10, 2009 at 3:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Every "Dino" oil is formed useing a Paraffrin based crude.
  14. May 10, 2009 at 3:13 PM
    DanGer
    Shit man i thought it was year based
  15. May 10, 2009 at 3:14 PM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    What about mobil 1?
  16. May 10, 2009 at 3:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    There used to be a myth about synthetics causeing oil seals to break down, or Synth. Oils being too "Slippery", thus causeing issues. They are false, and Synth. oils are fine for any engine.
  17. May 10, 2009 at 3:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2. Have seen alot of crap in engines that have run the "Q", or Penzoil.
  18. May 10, 2009 at 3:17 PM
    DanGer
    good deal well i will let her run the penzoil for a trip home and when she comes down to visit I will change it out with mobile1
  19. May 10, 2009 at 3:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Mobil 1 is a good oil. I tore the top end off my 2.7 at 100K and it still looked new. Did a complete tear down on a Ford 300 c.i.d. straight 6 and it looked good as well. It had Mobil 1 in it from 30K on up to the 215K at which it had when we took it apart.
  20. May 10, 2009 at 3:27 PM
    JeffRock
    Capital region, NY
    Ah cool, A guy at work swears by it. Runs it in everything. boat, mowers, trucks.
