Help I ripped out wires now everything is messing up?????
Discussion in 'Technical Chat' started by TACO FOR LIFE, Aug 25, 2013.
  1. Aug 25, 2013 at 4:02 PM
    TACO FOR LIFE
    TACO FOR LIFE [OP] Well-Known Member
    Seth
    texas
    07 PreRunner
    Ok so I got stuck at the beach and I got pulled out from the rear and when I tied the strap to my frame behind the pumper it pulled out the wires going to my tail lights and the licence plate lights. But i tried to splice them back together and my turn signals wont work, and to make matters worse after this my cruise control wont set and my AC is blowing hot air, and when i go from park to reverse it wont go unless i use a heavy amount of force and when in drive it isnt shifting right. Could I have messed up my transmission or is it all the wiring being messed up.
    i drive a 07 prerunner SR5 with 4.0 V6
    this is my first thread so hopefully i did it all right?
  2. Aug 25, 2013 at 4:06 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    checked all fuses?
  3. Aug 25, 2013 at 4:07 PM
    TACO FOR LIFE
    Seth
    texas
    07 PreRunner
    i didnt think about that because when i put on my flashers the signals work
  4. Aug 25, 2013 at 4:15 PM
    TACO FOR LIFE
    Seth
    texas
    07 PreRunner
    ill go check but would that mess with my transmission too
  5. Aug 25, 2013 at 4:21 PM
    2000GTacoma
    Snow Hill NC
    if the brake fuse is blown it could
  6. Aug 25, 2013 at 4:25 PM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    The reason the cruise won't work is because of it being tail light related.
  7. Aug 25, 2013 at 4:32 PM
    TACO FOR LIFE
    Seth
    texas
    07 PreRunner
    when i put wiring beck together the brake lights started working again?
  8. Aug 25, 2013 at 4:37 PM
    BamaToy1997
    Bill
    Navarre, FL
    Due to the way the system is wired, the turn signals run off a different fuse than the hazards. Thus hazards will still work if turn signals are inop. That is why the turn signals do not work, but the flashers do. I would recommend checking all of the related fuses.
  9. Aug 25, 2013 at 4:38 PM
    TACO FOR LIFE
    Seth
    texas
    07 PreRunner
    ok would these be in the fuse box in the cab out under hood?
  10. Aug 25, 2013 at 4:40 PM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    as far as your shiter being stuck in Park (P) and you having to use "Force".....it was probably locked because of a fuse blown dealing with wires with the taillights/towing harness. locate your fuse under your dash that says IGN 1 fuse it'll be a 10amp, its probably blown. that will affect your shifter and AC
  11. Aug 25, 2013 at 4:40 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    I'm not sure, but it's a good idea to go through both, pull every fuse, inspect, and put it back if it look good.
  12. Aug 25, 2013 at 4:48 PM
    TACO FOR LIFE
    Seth
    texas
    07 PreRunner
    ok ill pull all, IG 10 is blown but how do you take the ones out from under the hood they wont pull out like the other flat ones
  13. Aug 25, 2013 at 5:04 PM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    you should have a fuse puller on the underside of the lid. should be white.
  14. Aug 25, 2013 at 5:05 PM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    replace that one and your shifter will become unlocked and AC will blow cold again.
  15. Aug 25, 2013 at 5:06 PM
    Redfox1
    Redfox1 'Stralia! Riding Roo's and wrangling koalas
    Conner
    Santa Paula, CA and SLO
    09 Prerunner Sport TRD
    Browning Floor Mats, 275/70/17 BFG All-Terrain T/A's, Procomp 7089 wheels,Rear Spring TSB, Bilstein 5100's, LED roof light, seatbelt chime disabled, CB, UWS Toolbox,
    Fuse pulled? Little white tweezer looking contraption
  16. Aug 25, 2013 at 5:06 PM
    Redfox1
    Conner
    Puller*
  17. Aug 25, 2013 at 5:07 PM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    thats my knowledge for this thread...im done for now.
  18. Aug 25, 2013 at 5:08 PM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    yes, thats a fuse puller.
  19. Aug 25, 2013 at 5:09 PM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    97 more posts to go, then im finally at 1000...lol
  20. Aug 25, 2013 at 5:20 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    addict :p
