HELP!...I scratched my paint!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by broders, Dec 10, 2015.
  1. Dec 10, 2015 at 5:21 PM
    broders
    broders [OP] Well-Known Member
    NC
    2016 Toyota Tacoma TRD Sport DCLB
    So I'm new at all this stuff and tonight I was removing the stupid sticker decal that the dealerships put on and once I was finished I noticed my paint was scratched to hell. Any suggestions how to fix?! Thank you in advance. image.jpgimage.jpg
  2. Dec 10, 2015 at 5:25 PM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Doesn't look too bad. Should do the trick.
  3. Dec 10, 2015 at 5:25 PM
    Justn868
    Justn868 Well-Known Member
    Justin
    Kansas City
    14 4x4 TRD OR
    Hit it with some wax :itllbuffout:
    smitty99 and DustStorm4x4 like this.
  4. Dec 10, 2015 at 5:27 PM
    dentpusha
    dentpusha Well-Known Member
    TEXAS
    16 ORAC
    Wax will hide it but it may need color sanded and polished out to get rid of it. A detail shop can do it if you don't have your own supplies.
  5. Dec 10, 2015 at 5:29 PM
    300AACTaco
    300AACTaco Well-Known Member
    Alaska
    Black '15 DCSB TRD Off Road 4x4
    ARB Old Man Emu 90000s and 60091s OME 886s, Trim Packer, Icon Tubular Uniball UCAs, CMC, Invisible Sway Bar, Dakar Rear Leaf Packs, Timbren Rear Bumpstops, All Pro U-bolt flip up kit, Method Race Wheels NV 16X8 4.5BS, Cooper ST Maxx LT285/75/16, DEPO Black Tail Lights, Weathertech Floormats, Cascadia Vehicle Tents Mt. Shasta in Earth Tone Green, Custom Green Tree Fabrication Bed Rack, N-Fab Spare Tire Bed Mount
    Does it catch your fingernail? If so it might be too deep. But you can at least try using a cutting compound with a polisher followed by a polish. Wet sanding helps mainly with removing orange peel in paint, not so much scratches but it can depend.
  6. Dec 10, 2015 at 5:34 PM
    dentpusha
    TEXAS
    16 ORAC
    Your right if you can feel it with a finger nail it may be too deep but I've removed thousands of light scratches with 5000 grit following 3000 then 2000 grit sand paper. Usually use 3m step number 3 to remove cuts then polish.
  7. Dec 10, 2015 at 5:37 PM
    300AACTaco
    Alaska
    With a process like that I can definitely see how you've removed a lot
    Tiny, mbroughton02 and travis.diller like this.
  8. Dec 10, 2015 at 5:40 PM
    travis.diller
    travis.diller Well-Known Member
    Travis
    Kitsap Peninsula
    2003 Taco prerunner 4x4
    fully armored, 4.88, 33 skinnies, tundra brakes, a REAL cold air intake.
    They must now be hidden under the other scratches...
    DustStorm4x4 and skiergd011013 like this.
  9. Dec 10, 2015 at 5:40 PM
    broders
    NC
    I can't feel it with my finger nail, can really only see it in certain light.
  10. Dec 10, 2015 at 5:41 PM
    300AACTaco
    Alaska
    that's the thing about wet sanding though is that you're removing a small amount of paint so it'll just keep leveling off the area, so if you can get the paint level with the scratch then it'll technically be removed, of course if the scratch is deeper than the clear coat then there's nothing you can do.
  11. Dec 10, 2015 at 5:42 PM
    300AACTaco
    Alaska
    then it can most likely come out of the paint
    DustStorm4x4 likes this.
  12. Dec 10, 2015 at 5:50 PM
    CAM37
    CAM37 Well-Known Member
    2016 Black TRD Sport
    Yep, a light hand polish should take them out if your fingernail doesn't catch on them. If that doesn't work, one product I've found will work on just about any scratch that doesn't get thru the clearcoat: Scratch Out made by Kit. Just a small amount on a microfiber cloth... ten seconds of light circular motion and presto... no more scratch.
  13. Dec 10, 2015 at 5:52 PM
    bdunna
    bdunna Well-Known Member
    2005 tundra access cab
    Good thing about buying a new truck is no one else scratched it all up. The bad thing I'd I made almost every scratch. Doh!
  14. Dec 10, 2015 at 5:53 PM
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport
    Stock
  15. Dec 10, 2015 at 5:55 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    DrFunker and vrod671 like this.
  16. Dec 10, 2015 at 6:01 PM
    twalchlii1
    twalchlii1 Tacotraitor
    Tom
    Wa
    2018 GC Trailhawk
    Are floor mats a mod?
    I had a little scratch on my bumper, but then I backed my truck into a dirt hillside turning around on a trail, but it had a big rock under the dirt. Now Don't notice the scratch so much! I would just take this as an opportunity to do mods to your truck! Ummm, maybe a plate rear bumper?
    Or go to a paint shop. ( boring)
    beertimecontinuum likes this.
  17. Dec 10, 2015 at 6:03 PM
    dmharvey79
    dmharvey79 Well-Known Member
    Dennis
    Northern Virginia
    It's a truck, the first of many if you use it like one. Character...
    travis.diller likes this.
  18. Dec 10, 2015 at 6:58 PM
    travis.diller
    Travis
    Kitsap Peninsula
    he's right you know...
    Get it out on the trail and that will be covered in dirt, and the rest of the truck will have the pinstripes!
  19. Dec 10, 2015 at 6:59 PM
    TMMIgirl
    TMMIgirl Well-Known Member
    Angela
    Haubstadt Indiana
    TRD off road DC SB
    What did you use to peel the sticker off, a paint scraper?
    travis.diller, DustStorm4x4 and GGB like this.
  20. Dec 10, 2015 at 7:27 PM
    Desert_Dawg
    Desert_Dawg Well-Known Member
    Dave
    Az
    2016 Quicksand TRDOR-DCSB
    A little advise. If you try this again use a blow dryer to heat up the sticker first,peal an edge and work your way down keeping the blow dryer ahead of the sticker. ;)
    TMMIgirl likes this.
