Help! I screwed up/got screwed with my lift
Discussion in 'Suspension' started by Zulu Six, Jan 19, 2011.
  1. Jan 19, 2011 at 7:14 PM
    Zulu Six
    Zulu Six [OP] Well-Known Member
    North Carolina
    2005 Tacoma Double Cab SR5
    Before I start, I want to say that I was/am a total noob to the lift scene. I got my hands on a little extra money, got impatient to get my truck lifted ASAP and didn't do nearly enough research. Don't be like me.
    I just had a decent kit installed. Toytec/Eibach coils, 5100's all around, a 2" AAL and a diff drop. The goal was a level 3" lift. When it came time to drop my truck off at the shop, the owner asked me what height I wanted the front 5100's set at. I said that I had no idea, but that I was looking for a level 3" lift. He said "well then I'd go with setting them at 2.5". Being a trusting and ignorant asshole that I am, I said go for it. I got a 4.1" lift, 0 caster and vibrations like you wouldn't believe.
    I installed a carrier bearing drop kit to see if that would help with the vibrations (it didnt). I backordered a set of TC UCA's to get some positive caster. I then went back and spent a week reading everything on these forums and spoke with the guys at ToyTec. Apparently I should have had the shocks set at 0 or 0.85 at the most - anything above that and a blown axle or shock is a sure thing. My truck is hanging out in the driveway until it goes back to the shop on Friday.
    Help me out:
    To get rid of the vibrations, should I set the shocks at 0 in front, giving me 1.6" lift with the springs and leave the 2" AAL in the rear? How bad will that rake angle look?
    If I stick with the 1.6" lift, should I pull the AAL?
    Should I set the front shocks at 0.85" for 2.45" front, 2" rear and try to deal with vibrations by way of the carrier bearing drop/shims?
    Should I cancel the UCA order while I still can?
  2. Jan 19, 2011 at 7:17 PM
    ChopperCam
    ChopperCam Well-Known Member
    Canada
    07 Blk Tacoma Double Cab
    Toytec lift, 5100's,Tint, Front grill,All pro front bumper, Warn winch, Hella Blk magic lights, piaa fog lights, Avic D3, TRD Exhaust, Cold air intake, fog light anytime, Tailgate mod, debadged,
    ^^^^subbed.....just ordered my Toytec ultimate lift, thanks for posting this info as Im am new to lifts as well. Hope it all works out for you.
  3. Jan 19, 2011 at 7:20 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    I hope your cv's are ok, I would set them at 1.75 with the uca's, but only if you are a prerunner
  4. Jan 19, 2011 at 7:20 PM
    BLKSR5TACO
    BLKSR5TACO Well-Known Member
    Craig
    Chesapeake, Va
    09 BSP Tacoma PreRunner SR5
    Tint / Debadged / Bed Lights / N-Fabs
    i'm not a suspension guru but some people that do eibachs usually set it at .85 with the 2" aal to achieve 3" overall level look. having the 5100's set at 2.5 and the eibachs i'm sure will do some damage if left like it is.
  5. Jan 19, 2011 at 7:23 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    set them at .85 and you'll be good to go, that should take care of most if not all of your vibes
  6. Jan 19, 2011 at 7:25 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    The 5100s can't be set at anything higher than .85 with the Eibachs (2nd setting).
    A 1.5" AAL and the billies at .85 with Eibachs will put you about level
  7. Jan 19, 2011 at 7:31 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    x2^^^^^^^^^
    and your vibe is most likely from the rear end.....
    you can try shims
  8. Jan 19, 2011 at 7:37 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
  9. Jan 19, 2011 at 7:38 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Set your billies at .85 and it'll level you out more Brock
  10. Jan 19, 2011 at 7:40 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    also measure from the center hub on your wheel
  11. Jan 19, 2011 at 7:42 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Brock your ass end is 2" Higher??....Thats ridiculous!
  12. Jan 19, 2011 at 7:42 PM
    Zulu Six
    North Carolina
    Awesome. Thanks for all the responses, fellas. It's reassuring when everyone is saying the same thing (set the shocks at .85).
    Two more dumb questions:
    1) The CV joint thing has me worried. Is there any way to check for wear? Any trouble signs I should be looking for?
    2) Should I pull the OME carrier bearing drop after lowering the truck?
    Thanks again
  13. Jan 19, 2011 at 7:44 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    1.Vibrations
    2.yes
  14. Jan 19, 2011 at 7:44 PM
    Zulu Six
    North Carolina
    Thanks for the link
  15. Jan 19, 2011 at 7:46 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    As above , .85 is max setting for Billies when paired with the Eibachs
  16. Jan 19, 2011 at 7:48 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    1. Post up some pics and it'll help us tremendously. :) Generally, when the fins touch or are close to touching, you really want to lower the lift in the front. If they are at a point to where they aren't too close but still enough angle to concern you, then that's something to consider.
    2. If you loose your vibes after lowering and don't have anything, then I'd leave them.
  17. Jan 19, 2011 at 7:48 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    dude you fuckin' crack me up! :D
  18. Jan 19, 2011 at 7:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    If the shop is that much in question, You may want to take a pic of the lower spring seat on the 5100's (The part that the bottom of the coil spring rests on), and post it up, so we can gauge if those were installed in teh correct orientation.
  19. Jan 19, 2011 at 8:22 PM
    Zulu Six
    North Carolina
    Will these do?
    [​IMG][​IMG]
  20. Jan 19, 2011 at 8:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I havent seen black spring seats on teh 5100's before....But yeah, Those look to be installed in the correct orientation.
