Help!! I stripped a nut..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BMiller421, Aug 13, 2011.
  1. Aug 13, 2011 at 5:10 PM
    BMiller421
    BMiller421 [OP] FMLYHM
    Brandon
    Bakersfield, CA
    05 Pre-runner
    LT, Kings, Fabricated Trucks Worldwide For The Win, K&N and Doug Thorley LT Headers
    Hey guys..
    I've been working on exchanging my headers all day..and am down to the last two lower nuts on the drivers side coming off the block.
    Any recommendations for tools that can get those last two 12 mm nuts off?
    Need to smog to pay my tags by the end of the month..
    Thanks in advance..
  2. Aug 13, 2011 at 5:24 PM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
  3. Aug 15, 2011 at 3:10 PM
    UMBCrew
    UMBCrew Well-Known Member
    Nic
    Central Valley, CA
    05 6" Pro Comp Stage II
    6" Pro Comp Stage II, 305/65r17 Pro Comp Xtreme AT, Pro Comp 7033 17x9s, AFe Stage 2 Si, All-Pro Rear Bumper, Ultra-Guage, Kenwood KDC-X895, Kicker 6.5 2 ways
    hey man that sucks, have you tried these
    Edit changed the site had the wrong one
    http://www.amazon.com/gp/product/B003M68V64/ref=ox_sc_sfl_title_2?ie=UTF8&m=ATVPDKIKX0DER
    Edit
    they grab the sides not the ends so there supposed to be able to get a stripped nut. ive seen them at sears or craftsmen has a similar model wrench. or have you tried a gator grip socket.
    http://www.amazon.com/Gator-Grip-ETC-200MO-Universal-Socket/dp/B000065CJ8
    they sell those at harbor freight and ive sometimes seen them at target at wal-mart. but i was just at harbor freight like thurs and i know they have them there.
    if those dont work i have two different easy-out sets that i could probably help you get it out with but those are a pain and dont work great in tight spaces or on rusted or really stuck bolts.
    let me know if there is anything i can do to help
  4. Aug 16, 2011 at 7:26 AM
    BMiller421
    Brandon
    Bakersfield, CA
    05 Pre-runner
    ^ I might have to stop by hf after work to pick one of those up..
    I picked up a stripped bolt kit from sears..those didnt work..so i'll give the one from hf a shot..then i'll let you know if I need a hand..
  5. Aug 16, 2011 at 9:40 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Heat it up, douse it with water. Repeat while trying to break the nut loose.
    Blaster may help in other areas, but exhaust needs more convincing!
  6. Aug 16, 2011 at 9:46 AM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Hehe, he busted a nut in his truck. hehehehehe
  7. Aug 16, 2011 at 11:20 AM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    Looks like if you go with the Amazon one's they have a lifetime warranty. Cant beat that! These are in my near future stripped bolts cause my fingers problems.
  8. Aug 16, 2011 at 11:53 AM
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
    Do you have a welder? You can weld a nut to the bolt head and then remove it. The heat from welding is often enough to break loose any rust, too.
  9. Aug 16, 2011 at 11:56 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    this^^
    my dad has done it before
  10. Aug 16, 2011 at 11:56 AM
    jeckel7234
    jeckel7234 Well-Known Member
    Drew
    VA
    05 Tacoma
    Add-a-Leaf, Leveling Kit, 31.5 Nitto Grapplers, Mag-Lite Mod, Anit-Key in the ignition beep mod, Tail gate theft mod, Trifecta tonneau cover, washable cabin air filter,
    those gator grip sockets are horrible i dont know if you already got it off but the first time i used it it got FUBAR, the pins in it started falling out
  11. Aug 16, 2011 at 11:59 AM
    t4r4life
    t4r4life poptard and protein farts
    Eric
    East Bay Area
    1998 Toyota 4runner
    panty dropping mod
    they work great : gator grip
  12. Aug 16, 2011 at 11:59 AM
    BMiller421
    Brandon
    Bakersfield, CA
    05 Pre-runner
    I do..and I might try that..
  13. Aug 16, 2011 at 12:01 PM
    BMiller421
    Brandon
    Bakersfield, CA
    05 Pre-runner
    But can they grab into a nut that is completely rounded?
  14. Aug 17, 2011 at 5:32 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
  15. Aug 18, 2011 at 5:11 PM
    UMBCrew
    Nic
    Central Valley, CA
    Did you get nut off yet or are you gonna be working on it all weekend?
  16. Aug 18, 2011 at 5:12 PM
    UMBCrew
    Nic
    Central Valley, CA
    And have you found replacement bolts yet
  17. Aug 19, 2011 at 7:51 AM
    BMiller421
    Brandon
    Bakersfield, CA
    05 Pre-runner
    I'm going to try working on it again tomorrow..you busy? Want to come over and help out?
  18. Aug 19, 2011 at 7:56 AM
    BMiller421
    Brandon
    Bakersfield, CA
    05 Pre-runner
    Tried those..no luck..
  19. Aug 19, 2011 at 9:15 AM
    UMBCrew
    Nic
    Central Valley, CA
    Yeah ill come help, tonight (fri) or tomorrow?
  20. Aug 22, 2011 at 12:18 AM
    UMBCrew
    Nic
    Central Valley, CA
    Well we conquered the bastard nuts, for those wondering or with similar problems we got one off with a simple 6 point deep impact socket on the end of a breaker bar which we had to remove the alternator in order to get enough swing room to move the breaker bar. The second nut = 4 1/2 inch angle grinder, nuff said.
