Help, I think I need to replace U-Joints?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by motoslug, Aug 29, 2022.
  1. Oct 17, 2024 at 3:14 PM
    #41
    motoslug
    motoslug [OP] Active Member
    Simon
    Installed OEM LCAs, new Cam bolts (one side was seized), OEM rack & pinion and power steering high pressure hoses.
    All went smooth except two Cam bolts seized. Front end is looking good. OEM parts were not cheap, about $1500 for everything.
    Getting an alignment tomorrow.
    Earlier this year I also replaced the straight pipe with a TRD performance exhaust - $400 from the dealer.
    Next up, get a shop to sand down any surface rust on the frame and repaint. And also fluid film undercoat this fall.
    Considering new plugs (current ones have 110k on them - but truck runs fine) and maybe fresh diff, transmission and coolant fluids?
    All is all, most of the problems have been fixed :)
    thomasburk likes this.
  2. Dec 24, 2024 at 8:00 AM
    #42
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
  3. Dec 24, 2024 at 8:16 AM
    #43
    motoslug
    Simon
    Originally I thought the creaking when turning was the LCA ball joints, but I'm fairly certainly it was from the Camburg UCA uni-ball joint that needed (dry) lubrication. Wasn't a total waste replacing the LCA, since those ball joints were pretty shot and I needed to replace the rack & pinion, so definitely better to do all those parts at the same time.
  4. Dec 24, 2024 at 8:25 AM
    #44
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    I agree, the Camburg UCA joint was probably the culprit to the creaking noise. Yes the LCA takes quite a beating too, and new parts on the suspension makes your ride feel like new. You got a great looking truck so enjoy enjoy it in it's newly refreshed condition.
  5. Dec 24, 2024 at 8:29 AM
    #45
    motoslug
    Simon
    much appreciated
