Help ID loud pop and shutter when flexing rear axle
Discussion in '1st Gen. Tacomas (1995-2004)' started by taco terror, Apr 21, 2014.
  1. Apr 21, 2014 at 7:46 PM
    taco terror
    taco terror [OP] 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    When I flex the trucks suspension, there is a really loud POP from the rear end somewhere. When it happens, the entire truck jolts. I have no clue what it is
    specs:
    Wheelers 5 leaf spring pack
    Bilstien 5100 socks
    new shackles
    https://www.youtube.com/watch?v=ySnew42SsAQ
  2. Apr 22, 2014 at 8:08 AM
    taco terror
    USA
    anyone have a clue?
  3. Apr 22, 2014 at 11:08 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I'm thinking that a moving part is coming in contact with a non-moving part while flexing, causing the noise. If so, you should be able to go under there carefully inspect where all the new parts are, and see a sign of wear (shiny metal rather than dirt and rust).
  4. Apr 22, 2014 at 4:08 PM
    taco terror
    USA
    I definitely will check that out when I can get to my truck towards the end of this week, although I did get out when parked on the hill and look underneath quickly. I didn't notice anything
  5. Apr 22, 2014 at 5:18 PM
    604YOTA
    604YOTA Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    What leaf springs are you running?
  6. Apr 22, 2014 at 5:49 PM
    taco terror
    USA
    Wheelers 5 leaf pack, as stated in the op
  7. Apr 22, 2014 at 8:46 PM
    islandlife
    islandlife Member
    Check the outer axle bearings.
  8. Apr 23, 2014 at 4:56 AM
    043RZ
    043RZ Well-Known Member
    Spring Grove, PA
    2004 Tacoma SR5
    6" Fabtech Lift, OME Dakar leaf springs, BudBuilt Traction Bar, 15" American Racing Wheels, 5.29 Nitro Gears, 35" BFGs AT, Pioneer 200 Watt Stereo, 6x8 Pioneer speakers, Raised Front and Rear Diff Breathers, Deck Plate Mod, Red Interior Underglow, Red Exterior Underglow, Cool White LED Rock Lights,
    Another thing i would check would be to make sure the springs arent making contact with you shocks when its flexing or at full compression. Not sure if your running blocks in the back but blocks tend to amplify this problem. Just a quick check you can eliminate. The other thing i was thinking was your slip yoke but iv never heard of one making a bang like that.
  9. Apr 23, 2014 at 5:14 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    regrease slip yoke on the driveshaft....I don't mean with a grease gun either, drop center support bearing, carefully yaw the whole driveshaft to one side slowly, make sure you mark the splines location, must go exactly in same spot, lather the splines with same grease your grease gun has, reassemble, wipe excess grease off, drive...see what is....you may be surprised, I was....
