help identify this TRD
Discussion in '1st Gen. Tacomas (1995-2004)' started by riotrob, Aug 16, 2011.
  1. Aug 16, 2011 at 6:53 PM
    riotrob
    riotrob [OP] Member
    Hi. New guy here.
    I pass this truck everyday on my drive home. If you guys can help me out with the year, I would be thankful. Also, the grey TRD sticker is throwing me off. Other than this truck, Ive only seen those stickers in either black or white. Does that mean that this is a fake TRD?
  2. Aug 16, 2011 at 7:03 PM
    Sanders17
    Sanders17 Well-Known Member
    Reed
    Livingston, TN
    Black Sand Pearl 08 TRD Offroad
    98 i think a friend of mine has the same truck but its not a trd so cant help you there
  3. Aug 16, 2011 at 7:08 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    California
    2002 Tacoma TRD SR5, 3.4, 5spd
    -Bilstein 5100 Series shocks on all 4 corners -Rancho HD lift coils -1/4" Toytec driverside top plate spacer -Toytec 1" diff drop -Wheelers 1.5" AAL's -Toytec 1" lift shackles -Revtek extended length BPV bracket -285/75/16 BFG KO T/A's -Pro Comp rims -ET Conical tyle lug nuts -Spidertrax 1.5" wheel Spacers -CV Boot slide mod -TRD skid plate -Magnaflow 14" round muffler -Shortened tailpipe hidden behind framerail -Toyota bug deflector -Weathertech floormats -Black leather seat covers -Valentine 1 Radar Detector
    My guess would be no, it looks like one of those Ebay stickers that come in a multitude of colors. Not too mention, didn't the TRD's in those years come with fender flares?
    A quick way to find out is to look through the driverside window to see if has the e-locker button...but don't get caught looking like you're casing it.;)
  4. Aug 16, 2011 at 7:09 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    Probably a fake sticker, I had the TRD All Terrain sticker on my 96..haha
  5. Aug 16, 2011 at 7:09 PM
    tacovic
    tacovic Well-Known Member
    MN/WI
    00 4x4 TRD
    stock for now
    Its a 98-00. And I believe it is not a true TRD because of the color of the sticker, and it does not have any fender flares.
  6. Aug 16, 2011 at 7:16 PM
    riotrob
    riotrob [OP] Member
    Thanks guys.
    Im keeping my eye on it.
    The diff drains on the right side, so that means no locker, right?
    Which would also mean not a true TRD?
  7. Aug 16, 2011 at 7:19 PM
    jcgarvey
    jcgarvey Well-Known Member
    SFV, Los Angeles, CA
    V6 PreRunner 4x2 TRD Off Road
    Jot down the VIN in the window and double check it on carfax or some other free website. Should pop up with year and sometimes will show options on the vehicle when it was sold.
  8. Aug 16, 2011 at 7:24 PM
    riotrob
    riotrob [OP] Member
    Badge on the tailgate says SR5 V6
  9. Aug 16, 2011 at 9:45 PM
    Tacoma mud
    Tacoma mud Well-Known Member
    Kyle
    TEXAS
    97' xtra cab sr5 4x4
    soon to come
    Ha this looks like my truck! Only mine has a little bigger lift and fender flares ;)
  10. Aug 16, 2011 at 10:01 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The tip off is the diff drain plug. On the right means it is an 8.4" diff, no e-locker.
    It wasn't until the '01 model that the thick black flares showed up. Prior to that, it depended on other "packages" as to whether or not you got flares.
  11. Aug 16, 2011 at 10:06 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    that's the same model year as mine, 98-00...THE BEST MODEL YEAR! :crapstorm:
    (but the model year's already been established. Just thought I'd add in :D )
  12. Aug 16, 2011 at 10:11 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    not if they were 4cyl
  13. Aug 17, 2011 at 8:07 AM
    MTgirl
    Weesa
    Bob's secret mod lair
    Now: 12 T4R SR5 Then: 99 - 3.4L SR5 4WD
    Wheeler's/Alcan 5-pack leaf springs, Bilstein 5100's front and rear, OME 881's, de-badged, Jungle Fender Flares, Herculined bed, HomerTaco grille, Anzo headlights, clear corners, CVT Mt. Bachelor RTT, custom bed rack & CBI sliders
    hmmm...white, xtra cab, trout unlimited plates. the owner has exceptional taste if i do say so myself! so where in MT are you?
  14. Aug 17, 2011 at 9:21 AM
    derekp
    derekp giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
    I had a 2000 X-cab TRD V6...Manual, it came with fender flares. Fender flares were part of the package as far back as 98.
  15. Aug 17, 2011 at 9:37 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    This is what the sticker should look like
    If it has 15" wheels it's from 98-00. If they're 16"s its 01-04. It looks like a SR5 package 4x4.
  16. Aug 17, 2011 at 9:58 AM
    derekp
    derekp giddy up!
    Derek
    Grand Forks, ND
    By looking at the front end, I can tell it is pre-2001.
  17. Aug 17, 2011 at 1:07 PM
    JBear
    JBear Spiral Out... Keep Going!
    Orange County, CA
    2003 Extra Cab 5 spd 4x4 TRD Off-Road
    2" suspension lift with King Coilovers up front. Standard Bilsteins on rear with a Fabtech 1.5" AAL. Leer 100XL Shell.
    99, give ot take a year
  18. Aug 17, 2011 at 1:15 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    you could get a 2.7l TRD in first gen
    therefore you could have a TRD without the SR5 V6 badging on the tailgate
    :p
  19. Aug 17, 2011 at 3:13 PM
    Zork
    Zork Well-Known Member
    CA / KY
    04 PreRunner V6 D-Cab
    Alpine CDA-9885
    Imposter! It does not have the bigger TRD Mirrors.
  20. Aug 17, 2011 at 3:31 PM
    Tacomada
    Tacomada Well-Known Member
    TBC - Canadiana
    2010 TRD Off Road
    Looks just like my old 98. Canadian model of course... ;-)
    1998 base v6 4x4, only visible difference is the absence of the silly little fender trim...
    Edit: and there appears to be a badge behind the rear side window.. Sr5?
