Help identifying engine noise/problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mxpatriot, Feb 26, 2010.
  1. Feb 26, 2010 at 3:45 PM
    Mxpatriot
    Mxpatriot [OP] Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    At stoplights (idle) and at very low speed (generally 5 MPH and under, in both forward and reverse), I'm getting a "clicking" sound from my engine compartment. It almost sounds like something is getting hit by the fan blades.
    I've looked around and can't find anything obviously wrong, with the fan or the belt. The belt is the original belt (I'm at 76K miles), so I suspect that's it, but before I either go down and buy a belt or take it to the dealership or shop, anyone have any idea what could be causing this noise?
  2. Feb 26, 2010 at 3:54 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Hmm have you checked your motor mounts?
  3. Feb 26, 2010 at 4:12 PM
    Mxpatriot
    Chase
    North Pole, Alaska
    Money pit.
    that would be a concern... I'll have to get in there and look
    Is this something that could be caused by that?
  4. Feb 26, 2010 at 4:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Do you have a "Cold Air Intake"?
  5. Feb 26, 2010 at 4:31 PM
    Mxpatriot
    Chase
    North Pole, Alaska
    Money pit.
    No
  6. Feb 26, 2010 at 4:31 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Are you certain it isn't the normal Tacoma tick?
  7. Feb 26, 2010 at 4:31 PM
    Mxpatriot
    Chase
    North Pole, Alaska
    Money pit.
    Yea I've had the truck for two years and 50K miles and haven't heard it before
  8. Feb 26, 2010 at 5:44 PM
    Mxpatriot
    Chase
    North Pole, Alaska
    Money pit.
    Well maybe it is that Tacoma tick I'm taking it in to the dealer tomorrow hopefully they fix it under the exhaust manifold tsb that I think correlates to the Tacoma tick
  9. Feb 28, 2010 at 2:29 PM
    Mxpatriot
    Chase
    North Pole, Alaska
    Money pit.
    Dealership confirmed it's the "tacoma tick" and they're going to do the TSB on it. Covered under warranty, but I was 3K miles from being out of warranty - thank God - it's $1500 in parts alone.
  10. Feb 28, 2010 at 2:34 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Since when did we get a Tacoma Tick TSB?
  11. Feb 28, 2010 at 2:57 PM
    MY50cal
    MY50cal - IPFK -
    Mojo
    Chester County, PA
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    x2
    :notsure:
  12. Feb 28, 2010 at 3:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Probably the Exhaust manifold
