Help identifying hose spraying air and fuel?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Vultam, Jan 20, 2024.
  1. Jan 20, 2024 at 2:12 PM
    Vultam
    Vultam [OP] New Member
    2019 Tacoma TRD Off-Road
    Lift, Winch, Lights
    Started my 2019 Tacoma 4WD this morning for the first time in over 2 weeks since we were out of town. Battery was dead so I had the hood open, thankfully!
    When it started I noticed a ton of mist spraying up from the engine bay on the right side. Upon turning off the truck and investigating, I immediately smelled gas.
    Unfortunately it looks like there’s squirrel/rodent damage on a small hose. Can someone help me identify this hose? Any advice on how to replace this hose? Attaching images.Thanks for any help!
  2. Jan 20, 2024 at 3:10 PM
    jss1975snow
    jss1975snow Well-Known Member
    Jamey
    Delaware
    2018 Tacoma TRD OFFROAD
    Contact a Toyota Dealer, just received a letter 23TE01 about a fuel seepage odor around high fuel pump 10 years from first usage.
  3. Jan 20, 2024 at 3:15 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Looks like the (low pressure) feed from the fuel tank, it goes to that high-pressure pump sitting on top of the engine.
  4. Jan 20, 2024 at 6:56 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I think it called no.2 fuel tube sub-assembly.
    Need to take the intake off to replace.
  5. Jan 20, 2024 at 7:06 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    good catch! That could have went bad fast!
  6. Jan 20, 2024 at 9:37 PM
    Dead-Weight
    Dead-Weight Well-Known Member
    Scott
    Sedalia, CO
    ‘22 OR Lunar Rock
    Pine tree air freshener
    Definitely! Had the potential to go way south pretty quick. Good luck on getting that line repaired.
  7. Jan 20, 2024 at 10:18 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I almost hate to suggest this, but is this repairable by cutting out the damaged section and splicing in a new piece with some tubing connectors and hose clamps?
    Big tall dave likes this.
  8. Jan 21, 2024 at 3:51 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Terrible idea … it’s a fuel line and should never be modified.
    Chew and TS4x4 like this.
  9. Jan 21, 2024 at 4:38 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    It’s a rubber fuel line, nothing special. There’s nothing wrong with using barbed fittings and new fuel rated tubing to make a repair.
    MannyS, OldSchlPunk and ljerr2 like this.
  10. Jan 21, 2024 at 4:55 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Get the new part from a dealer. Likely they have it on hand and can show you a parts breakout to ensure the correct part. Good luck, great catch
  11. Jan 21, 2024 at 6:23 AM
    Buck Henry
    Yeah, that's what I was thinking. Back in my poor youth, we patched shit like this all the time as we couldn't afford anything else. Seriously, I probably have everything the OP needs to patch this down in my workshop. :)
    Having said all that, OP should evaluate the repair options and make the best decision for his vehicle.
    Big tall dave, OldSchlPunk and ljerr2 like this.
  12. Jan 21, 2024 at 6:56 AM
    Vlady
    Issy, WA
    The orange clip the the picture is a low pressure line. Op has issue with the other line -high pressure line.
    ljerr2 likes this.
  13. Jan 21, 2024 at 7:49 AM
    Drippy4x4
    Drippy4x4 Keeper of the Air Dam
    '22 SR5 Taco
  14. Jan 21, 2024 at 8:11 AM
    Buck Henry
    If the high pressure line is rubber coated steel, then forget my idea!
    OldSchlPunk likes this.
  15. Jan 21, 2024 at 8:41 AM
    Vlady
    Issy, WA
    3000 psi
  16. Jan 21, 2024 at 8:53 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
  17. Jan 21, 2024 at 8:56 AM
    Bishop84
    Bishop84 Well-Known Member
    Will they even return?
    Best course of action is just go to the dealer or email them the photo. This part is one of those things that should be done in person. I think its a return hose that goes behind the intake, but not certain.
    b_r_o[QUOTED] likes this.
  18. Jan 21, 2024 at 9:00 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    If it's a high pressure steel line under the rubber, I don't want to meet the rodents that chewed through that.
    b_r_o likes this.
  19. Jan 21, 2024 at 9:02 AM
    Vlady
    Issy, WA
    Gen3 is returnless system
    Bishop84[QUOTED] likes this.
  20. Jan 21, 2024 at 9:08 AM
    Bishop84
    I think one is feed and one is return to the port side. The diagrams are terrible for the fuel system but it makes the most sense.
    I think it makes the most sense as the low side doesnt need a return but the high side pump certainly needs some where for pressure to leave.
    Not stating as fact, if anyone has any real info please correct.
    Looks like low pressure feed, low pressure damper return to low, and high pressure to DI.
