Help identifying illumination wire on cargo light switch
Discussion in 'Lighting' started by Donkeythekidd, Nov 1, 2016.
  1. Nov 1, 2016 at 3:32 PM
    Donkeythekidd
    Donkeythekidd [OP] Well-Known Member
    Beaumont, CA
    2017 MGM Tacoma TRD Off Road Double Cab
    Hey guys I need some help identifying the illumination and ground wire going into the cargo light toggle switch. I want to use that to tap into. I'm hooking up a toggle switch next to it and have already hooked up the toggle to my accessory so that it turns on and off with the push button but I now need to hook it up so that the button lights up with my other dash lights. I have a 2017 Tacoma off road. Here is a picture of the back of the cargo light switch. 20161101_134638.jpg
  2. Nov 1, 2016 at 6:22 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    does the toggle switch have a dedicated light circuit? power and ground only for the indicator. is it an LED? I am asking so you don't unintentionally short out your truck.
  3. Nov 1, 2016 at 6:26 PM
    Donkeythekidd
    Beaumont, CA
    I want to say yes. Here is a picture of the wire diagram for the toggle switch I'm installing 20161024_131837.jpg
  4. Nov 1, 2016 at 6:33 PM
    Donkeythekidd
    Beaumont, CA
    I have already connected wire 1 & 2 so my bed speakers come on when I push the button. Now I just need to connect the other two so that it lights up when my dash lights are on. I want to tap into the outside cargo light switch 20161101_182808.jpg
  5. Nov 1, 2016 at 6:41 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    Unfortunately, you can not hook that switch into the stock illumination circuit. That switch uses the ground wire for both the dash illumination and when activated.
  6. Nov 1, 2016 at 6:41 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    here is the answer for someone that comes across the page
  7. Nov 1, 2016 at 6:46 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    You can still illuminate that switch off the taillight circuit. An add-a-circuit to the fusebox can provide the power for the dash wire on that switch. You won't be able to dim it with the rest of the stock illumination.
  8. Nov 1, 2016 at 6:52 PM
    Donkeythekidd
    Beaumont, CA
    Ok Thanks I'll try that.
  9. May 2, 2017 at 9:22 AM
    COdude3
    COdude3 Well-Known Member
    Colorado
    2017 SR5 Access Cab 4x4
    Pro Grille, Pro Whls, King Shocks, 265/75R16 A/T3
    Did you ever figure out your solution? Does tapping into the ILL- and the ILL+ allow the CH4x4 switch to dim? I read on another post that this worked, but fergyz says otherwise. I know nothing about electrical and want to make sure it will work before I tap into the wires.
  10. May 7, 2017 at 8:56 PM
    Donkeythekidd
    Beaumont, CA
    Yes I did. I connected the red 2 #3 wire coming off my switch to the green wire on the cargo switch and the black #4 coming off my switch to the tan wire on the cargo switch. It functions just the way I wanted it to. Lights up with the rest of the switches, dimes with the odometer dimmer switch, and the top part of the switch lights up when active. It also turns off when the rest are off.
    vicali likes this.
  11. May 10, 2017 at 6:02 AM
    COdude3
    Colorado
    Thanks. I'm thinking about doing the same.
  12. Jun 10, 2017 at 12:11 PM
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    how are you getting power to your relay? im not getting anything when I wire like that. I have (1# Green to inline fuse) (2# Red to relay) (3# red 2 to green illum+) (4# black to tan illum-)
  13. Jun 10, 2017 at 1:37 PM
    Donkeythekidd
    Beaumont, CA
    I think you have the first two wires you mentioned switched. The #1 green wire goes to the source and the #2 red 1 goes to the relay or accessory
  14. Jun 10, 2017 at 3:49 PM
    ajsabra
    Sin city
    Not according to the picture diagram above
  15. Jul 23, 2017 at 2:12 PM
    TacoMA36
    TacoMA36 Member
    2016 TRD OR 4x4 AT DCLB
    Trying to tie in more bed lighting via a relay into to cargo switch rocker. Do you happen to know which wire in this harness is the switched-on wire that goes to the cargo light/relay?
  16. Jul 27, 2017 at 7:40 PM
    caribe makaira
    Caribbean, Puerto Rico
    Blue to added relay pin 85.
  17. Aug 3, 2017 at 12:41 PM
    TacoMA36
    TacoMA36 Member
    Great, thanks. Looks like the blue wire is a normally closed circuit showing 12v when off and no voltage when switched on. So the the added bed light should be connected to relay pin 87a and not 87, does that sound correct?
  18. Aug 4, 2017 at 8:31 PM
    caribe makaira
    Sorry it's to pin 85 on your added relay for the additional LED's.
    Quicksander17 likes this.
  19. Mar 7, 2018 at 12:22 PM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Do your switches still run good using this configeration?
  20. Sep 5, 2019 at 1:33 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Thanks for this....I put meter on Switch Pin 5 (blue) to ground...it showed 12V when the Cargo Light was OFF and zero V when the cargo light was On? This feels backwards to me. It does toggle with the door switch, but again it is energized when the light is off?
