Help Identifying side steps.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Brian4.2, Oct 13, 2020.
  1. Oct 13, 2020 at 8:32 PM
    Brian4.2
    Brian4.2 [OP] Well-Known Member
    Brian
    2016 white 4x2 offroad
    I went thru pep boys with a crap magnet, got it all
    I traded my TRD 2WD for a TRD 4x4. New truck has steps and rail. I need help identifying them. IMG_0573.jpgIMG_0574.jpgIMG_0576.jpg
  2. Oct 13, 2020 at 8:38 PM
    tcjacado
    tcjacado Well-Known Member
    They kinda look like the new oem predator steps that come on the 3rd gens
    PilotguyPA28 and LivinOnEdge like this.
  3. Oct 13, 2020 at 8:39 PM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Toyota Predator Tube Steps
    tcjacado likes this.
  4. Oct 13, 2020 at 8:41 PM
    LivinOnEdge
    Land of The Lost
    They do look slightly more edgier than round. Maybe a newer model of steps or the pictures are just not giving me all the details. These also stick out further than predators and theres no exposed bolt on top of the OEM predators either. Now im curious.
  5. Oct 13, 2020 at 8:42 PM
    tcjacado
    They don't look as tucked into the rocker panel like normal, could be the picture angle.
    LivinOnEdge[QUOTED] likes this.
  6. Oct 13, 2020 at 8:42 PM
    Tacoma_SR5Pro
    Tacoma_SR5Pro Well-Known Member
    '16 SR5 Pro
    They look like the predator steps but with erectile dysfunction. :D
  7. Oct 13, 2020 at 9:18 PM
    USATRDR8CR
    USATRDR8CR Well-Known Member
    Orange County, CA
    2018 MBM TRD OR DCLB
    Aftermarket Predator Step replicas
  8. Oct 13, 2020 at 9:41 PM
    Brian4.2
    Brian
    They actually tuck up pretty close, on a slot so you could go a little higher. I guess predators it is. Thanks alIMG_0581.jpg IMG_0580.jpg IMG_0579.jpg IMG_0578.jpg IMG_0577.jpg IMG_0581.jpg
  9. Oct 13, 2020 at 10:17 PM
    mjcollum
    mjcollum Well-Known Member
    Texas
    2021 AG OR 6MT
    they dont really look like oem toyota predator steps.
    visually close, but the details are wrong.
    the end caps are wrong at least, the pipe angles are off a bit, and the brackets that hold the steps are weird.
    and i dont remember the oem ones being open on the inside.
    and the predator mounting tabs are not bolted to the bars.
    they are closer to these...
    https://www.topgearautosport.com/18...-S8HiDIhb3zuCpg-hy1DcAl2aUlZSZ8EaAgxkEALw_wcB
    maybe the same company?
  10. Oct 14, 2020 at 4:43 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Predator steps ?? I don’t understand you post ... need help identifying..??? Is there a reason like your trying to see what they are worth ?
  11. Oct 14, 2020 at 2:30 PM
    mjcollum
    Texas
    2021 AG OR 6MT
    and i dont understand your confusion.
    OP has steps that look like the OEM sidesteps known as toyota "predator" steps.
    But they are not actual oem predator steps.
    they appear to be a knockoff, and the op was trying to figure out what brand they are.
    the reason is immaterial, but maybe they need a value to sell them?
    LivinOnEdge likes this.
  12. Oct 14, 2020 at 2:33 PM
    LivinOnEdge
    Land of The Lost
    Yup, these are VERY close to OEM predators but definitely not the same. They stick out to far and have more sharp creases unlock the oem predators which are flush to the cab and hav smoother edges. The brackets holding the step are also different marginaly.
  13. Oct 14, 2020 at 2:37 PM
    averagejp
    averagejp Well-Known Member
    2005 Black Tacoma Extended Cab
    Work in progress
    Really hard to tell since there are so many steps out there but they look like some version of these steps made by Westin. I could be wrong, of course, but they look more like these than the OEM Predator steps.
    https://runningboardwarehouse.com/p/westin-hdx-black-stainless-drop-steps/
    Seems like the best bet is to look on Running Board Warehouse or Amazon and try to do a visual match. These were the closest that I could get. Hope that helps !
  14. Oct 14, 2020 at 2:37 PM
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    Cheap E-Bay Steps. I used to have these and they are terrible. You'll just need to do an eBay search to find the double cab version:
    https://www.ebay.com/itm/For-2005-2...ning-Board-Nerf-Bar-Side-Step-BT/223647720167
    Look at the way it mounts in the back -- there's a joint there along with a sliding track. Also that single bolt in the very front of the step is a dead giveaway and is why they're horrible. It doesn't mount to both forward bolt-holes like OEM and thus it's extremely unstable.
    I took a few pictures of these because I thought they looked cool and then promptly replaced them with sliders.
  15. Oct 14, 2020 at 2:38 PM
    LivinOnEdge
    Land of The Lost
    They look nothing like this...
    o_O
  16. Oct 14, 2020 at 2:38 PM
    LivinOnEdge
    Land of The Lost
    This is the most logical answer.
