Help identifying this noise.
Discussion in '1st Gen. Tacomas (1995-2004)' started by trdracing5, Sep 27, 2020.
  1. Sep 27, 2020 at 9:31 AM
    trdracing5
    trdracing5 [OP] Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
    When I start my Tacoma I hear this clicking/tapping noise.
    Seems to be coming from under the dash on the passenger side.
    Anyone got any suggestions on what it is?
    https://youtu.be/8mrTGqGamg0
  2. Sep 27, 2020 at 9:52 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Does it make the sound with all the A/C controls OFF.
    Turn everything off, the fan, the AC and Recirculate.
    Then see if it still makes the noise. That way you can pretty much eliminate the Heat/AC system.
  3. Sep 27, 2020 at 10:13 AM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    No idea. Have you tried pressing down on the passenger side of the dashboard? Might sound dumb but it's helped me eliminate noises from that area.. not this specific noise though
  4. Sep 27, 2020 at 10:48 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    That’s where the blower hvac fan is - I’d do what @TnShooter suggested.
  5. Sep 27, 2020 at 3:36 PM
    trdracing5
    Elizabeth City, NC
    2003 Tacoma SR5
    So I tried to identify the part that is making the noise. If I push on the part that is circled the noise goes away. Any idea what this part is? 64AE29CA-D73A-4CA8-8E48-9E5601117116.jpg
  6. Sep 27, 2020 at 6:21 PM
    ECO Lander
    ECO Lander Well-Known Member
    Is your air mix servo motor. After a while when they start to fail they start making a tapping noise. Eventually, it will fail causing the blend door to stay closed which means no heat. It basically allows heat into the cab when you turn the dial from cold/hot. This sound bugged me for the past 6 months until my heat did not turn on last week. I just replaced it (autozone has a replacement $30). Its held up by 3 screws and a wiring harness. 10 minute switch out. Mine ran for 6 months making that sound but you may just want to switch it out.
    This video was very helpful
    https://www.youtube.com/watch?v=yRRcLVNqgC8
    trdracing5[OP] and crazytacoman like this.
  7. Sep 28, 2020 at 6:35 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Another good video for my library. Thanks for posting it!
