Help ID'ing my axle/diff and gear ratio
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KRAMERICA, Dec 14, 2016.
  1. Dec 14, 2016 at 5:46 PM
    KRAMERICA
    KRAMERICA [OP] Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    I have a 2012 TRD Double Cab Off-Road. It's an auto with the factory E-Locker, and tow package. The data plate gives the A/TM code A04C/A750F. Best I can decipher it means I have a 7.5" Ring Gear, 4.56 Ratio, and 2 Pinion OEM Limited Slip.
    The 7.5" ring gear has me a bit confused. I though the OR's came with the 8" ring gear. Can someone please help clear my head on this? I also thought in 2012 Tacoma's were made in Texas, but this says made in Mexico...WTF
    http://www.lcengineering.com/LCTechPages/DIFFERENTIALTOYOTATECH.html
  2. Dec 14, 2016 at 5:55 PM
    dofartshavelumps
    dofartshavelumps Well-Known Member
    NH
    2015 SR DCSB 4x4 4.0 MT
  3. Dec 14, 2016 at 6:12 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    all off road 2nd gen have an 8" 3.73:1
    ItalynStylion likes this.
  4. Dec 14, 2016 at 6:14 PM
    Pigpen
    Dan
    Northwest Montana
  5. Dec 15, 2016 at 2:13 PM
    KugelBlitz
    KugelBlitz Well-Known Member
    Warren
    Middle-GA
    2015 4WD, 6MT, TRD Sport Access Cab
    Bilstein 61112/5160, Dakar EL096R, 285/70-R17 C BFG K02, Level 8 Mk6 wheels, Bestop Softop US. OffRoad Hidden Winch Bumper, ComeUp DV-9s winch, SOS Concepts Sliders and IFS Skid plate, VIAIR 400P Auto compressor mounted in a Expedition Essentials bedside mount, TRD Quick Shifter, TRD Cat-Back exhaust, ,75WX ST CB, Pioneer AVH-X4800BS, and various other mods and things...
    Are these codes for the rear diff only, or are they the same for the front diff?
  6. Dec 15, 2016 at 2:16 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Good, question. I don't know where the codes for the front are, or if there is just one type for the 4WD's.
  7. Jan 14, 2019 at 10:05 PM
    lilcez3
    lilcez3 Well-Known Member
    None yet
    Hi OP, just came across this thread & I have the same gear ratio on my truck. It looks like you are running 3inch lift with 33s on your Taco. I'm planning to do the same.
    Have you felt the need to regear? Does it handle the lift and 33s well?
  8. Jan 15, 2019 at 5:27 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I am on a 3" lift with 33s, but I actually have regeared the truck from the stock 3.73 gears to 4.56 from ECGS. I wheeled it pretty hard on the stock gears without any major issues and know several folks that are still running stock gears on 33s. I opted to up the ratio because I plan to go to 35s in the near future. Though I'm not upset at all with the power 4.56 gears deliver on 33s! If you can swing the coin I think it is worthwhile to upgrade, though it is not mandatory for 33" tires.
