Help...I'm stuck!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bonsai3s, Feb 26, 2011.
  1. Feb 26, 2011 at 12:28 PM
    bonsai3s
    bonsai3s [OP] Active Member
    Fresno, CA
    09 TRD, Off Road, Prerunner
    I'm installing the EZ 43601 tailgate support. It was relatively easy and I was 2 steps from finishing the install...but when I got to removing the bolt (40 torx) from the tailgate, I managed to stripped the bolt (40 torx is now zero torx!). I know I will have to get a new bolt but I need suggestions on how to remove it first. I'm stuck. Thanks. :(
  2. Feb 26, 2011 at 12:44 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    Easy out. It's like a reverse drill bit. Any auto parts store should have one. They are also called bolt extractors. I've used them a few times and the work well.
  3. Feb 26, 2011 at 12:46 PM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
  4. Feb 26, 2011 at 1:48 PM
    bonsai3s
    Fresno, CA
    Thanks guys...here's a photo of mistake...
  5. Feb 26, 2011 at 1:55 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    vice grips if you can grab it
  6. Feb 26, 2011 at 5:50 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Couple of choices.
    1. EZ out. You can buy one from Lowes or Home Depot
    2. Drill out the head about 2/3 deep. Hammer in a larger hex driver into the head and reform the head to a hex... This will be very HARD and may not work depending on how soft/hard the bolt that is stripped out is. Turn the bolt carefully and back out the bolt.
    3. (last option) Drill out the head and go down thru the bolt with a drill bit that is one size smaller than the bolt that is stripped... be very careful... the next step will be to run a tap down and clean out the thread. This isn't easy but I've done it on my wife's Sequioa and it worked.
    Edited: changed the order...
  7. Feb 26, 2011 at 5:52 PM
    Dibblit
    Dibblit Eh?
    Paul
    Stony Plain
    Truck
    Icon Suspension ARB OBA
    weld a nut on it and use a wrench or socket
  8. Feb 26, 2011 at 5:54 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    I believe the part is labeled for 2005-2008 Tacos only... Those torx screws appear to be tack welded in '09+ trucks.
    Open the tailgate liner and have a look at the screw from the inside. Maybe you can drill out the screws completely and use conventional nuts and screws to hold the new bracket in.
  9. Feb 26, 2011 at 6:06 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    question is, why did you keep going when it started to round out?
  10. Feb 26, 2011 at 6:06 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    if you dont want to buy bolt extractors or dremmel a slit across it for a flat head, just grab it HARD with a big ass pair of vise grips and slowly turn it out
  11. Feb 26, 2011 at 6:10 PM
    CraigTRD
    CraigTRD Canadian in the South
    Craig
    London, Ontario, Canada
    Tacoma
    6" FabTech Lift, Custom rear leaf packs, RedLine gas hood props :D, Hockey Stick Canadian Flag Mod. 2012 Front
    X2. Just tack it a few times, don't WELD it or you'll eff other stuff up from heating it up too much.
    I have had pretty much zero luck with those damn EZ Out POS bits....
    Good luck whatever you do!
    The dremel trick would be my 2nd choice. Do you have an impact hammer?
  12. Feb 26, 2011 at 8:19 PM
    bonsai3s
    Fresno, CA
    It was stupid on my part...I'm the type that don't easily give up. Bottom line, I screwed up. I went to Home Depot and got a set of one of those EZ outs. I'll drill it, tap it in, and see if it works. If that doesn't work, I'll cut a slit with my dremel tool and use a large screwdriver. If that still doesn't work...man, I'll start drilling (carefully) until I get the bolt out. I'm just glad this forum exist...thanks guys!
  13. Feb 26, 2011 at 8:56 PM
    RZRob
    RZRob Well-Known Member
    Robert
    Anaheim Hills
    I would think if you can remove the other bolt, just drill out the head (it's a taper-head) then once you remove the part that's bolted on, grab the remains of the bolt with a simple Vice-grip.
    RZ Rob
  14. Feb 28, 2011 at 5:27 PM
    bonsai3s
    Fresno, CA
    Update: The Black and Decker EZ out did not work...it broke. I tried drilling...this will take some time. I managed to cut a nice slit for a large size screw driver. I'll try that when I visit my brother. He's got a small torch. I plan on using a large screwdriver after heating it up. (CraigTRD..no, I don't have an impact hammer. KenLyns...you may be right...it could well be tack welded.) Thanks guys!
  15. Feb 28, 2011 at 5:34 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    The "Big Nig"
    Lifted, Locked, Armored. Ready To Wheel.
    HAHA O SHITTTT that sucks. Definitely keep us posted on what you do next. I've heard those ez down tailgate dampners can be real tricky. I'd like to see if you manage to get it to work.
    Good luck :thumbsup:
  16. Mar 21, 2011 at 1:07 PM
    bonsai3s
    Fresno, CA
    Final update: Got the tailgate dampener finally installed. My brother (a Harley guy who's got every tool in the world) first drilled it. He then used his blow torch to heat it up really good, hammered another ez out in the hole and voila!...damn tapered bolt came right out! It was easy to finish after that. NOTE: Much like every one else who installed this dampener, we discovered that the tailgate cable is now getting in the way of the dampener when closing the tailgate. You can still close the tailgate but as my brother said...it was annoying having to move the cable out of the way every time you close the tailgate. Next step would be to replace the cable with a thinner more flexible cable that will not bind with the dampener. Thanks guys!
  17. Mar 21, 2011 at 3:23 PM
    outxider
    outxider Well-Known Member
    Sang
    Bay Area
    06 DCSB 4x4
    A few mods here and there and counting....
    I remember from a post on here, someone used a zip tie to hold the cable back to prevent it from getting in the way of the cable. He said it worked out well for him.
