HELP Im the highway and LF Wheel locked up getting C1406 &C1408
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jboudreaux1965, Jul 1, 2024.
  1. Jul 1, 2024 at 10:55 AM
    jboudreaux1965
    jboudreaux1965 [OP] Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    8 have have tones of speed sensors go bad, caliper never locked up! Any ideas to unlock it to get home?
  2. Jul 1, 2024 at 11:00 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    I can restart the , I can roll a couple of tire revolutions then caliper locks up. If I go in reverse it does not lock up? I turned VSC off, didn't help
  3. Jul 1, 2024 at 11:02 AM
    saajanpatel1
    saajanpatel1 Well-Known Member
    Saaj
    MA
    2022 Tacoma Limited
    None
    Any noise coming from the wheels when driving?
    Any work done on the brakes or wheels recently?
  4. Jul 1, 2024 at 11:02 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That sounds like a seized caliper or a blocked compensation port in the master cylinder. A blocked port would affect at least both calipers though.
    You might want to pull the wheel and look? The wheel is likely to be pretty hot.
    shakerhood likes this.
  5. Jul 1, 2024 at 11:04 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The code might be from the sensor or wiring getting cooked? Wild guess there.
  6. Jul 1, 2024 at 11:19 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Maybe pull the abs fuse/relay!
    Just a guess here!
  7. Jul 1, 2024 at 11:24 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Looks like the wire melted, I'm guessing its shorting, I should be able to just cut the wire and run without the sensor right? I've run with dead or no sensors before
  8. Jul 1, 2024 at 11:27 AM
    Clearwater Bill
    Billy
    Largo Florida
    are you out of warranty, or is the area modified such that warranty would be denied?
    If in warranty won't Toyota come tow it?
    Jakerou likes this.
  9. Jul 1, 2024 at 11:28 AM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Shop I use helped me do a lift in my 08 broke the wire they are super thin.
    Had a abs light til we replaced it.
    A lot less tech back then.
  10. Jul 1, 2024 at 11:30 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Where is the fuse, under the hood?
  11. Jul 1, 2024 at 11:31 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    I have 7" lift, so it's got extensions on it. it's brand new, 3500 miles with Toyota Platinum warranty.
  12. Jul 1, 2024 at 11:33 AM
    cowfootball
    cowfootball Well-Known Member
    South Lake Tahoe, CA
    2022 TRD OR
    Are you talking about the ski/speed/abs sensor wire? You can just unplug it at the top of the mount where it joins the wire harness. I can't remember how easy it is to access with stock fenders but you could also pull it from the back of the caliper if you have a zip tie to keep it out of the wheel.
    That would at least allow you to test without cutting it.
  13. Jul 1, 2024 at 11:40 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The 3rd Gen is just as simple. The wires have polarity, but just about anything can be spliced in there or soldered. Precise resistance is not critical as I thought it would be.
  14. Jul 1, 2024 at 11:42 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Unfortunately, that is the most likely culprit. I'd be on the phone with your dealer. The lift is likely only warranted by the place that you bought it from.
    Jakerou, Chew and BillF1564 like this.
  15. Jul 1, 2024 at 11:48 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    @Bishop84 he's on the highway with a locked up caliper. Any suggestions?
  16. Jul 1, 2024 at 11:51 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    I can wait to have it towed, just don't want to sit here forever
  17. Jul 1, 2024 at 11:52 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    The caliper unlocks until it rolls forward a few times then it locks, I'll try pulling ABS wire out from the top I guess
  18. Jul 1, 2024 at 11:53 AM
    cowfootball
    2022 TRD OR
    Definitely do this. If you just want to test, you can unplug it from the back of the caliper. It's really easily accessed.
  19. Jul 1, 2024 at 12:03 PM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Not sure of location on the 23 was under hood on the 08
  20. Jul 1, 2024 at 12:03 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    I pulled the wires off all 4 sensors, I can roll further but front caliper still locks up ??
