Help in dealing with high pitched chirping sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DBA0010, Aug 27, 2025.
  1. Aug 27, 2025 at 8:12 AM
    DBA0010
    DBA0010 [OP] Member
    David
    2008 Silver Tacoma 4x4
    My truck has recently developed a high pitched chirping or whining sound. It occurs in any gear, with or without 4wd engaged, but only when I'm maintaining speed. If I'm accelerating, braking, or just coasting it goes away. Any help in identifying this is appreciated. I included a video of the sound in the attached zip file.
  2. Aug 27, 2025 at 8:14 AM
    Clearwater Bill
    Billy
    Largo Florida
    Sorry, not opening any zip file from a stranger with only 11 posts......... And I don't have a sandbox to play in.
    Jimmyh, DBA0010[OP] and spitdog like this.
  3. Aug 27, 2025 at 8:20 AM
    DBA0010
    DBA0010 [OP] Member
    David
    Fair enough. I'll try to figure out how to get the MP4 into a format that will upload.
  4. Aug 27, 2025 at 8:31 AM
    DBA0010
    DBA0010 [OP] Member
    David
    https://vimeo.com/1113612328?share=copy
    The link above goes to the video I uploaded on vimeo. And to be fair, I've only got 11 posts because I've not had any real problems with the truck. Anyway, appreciate any help you can provide.
  5. Aug 27, 2025 at 8:45 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Does it make that noise idling(not moving)..
  6. Aug 27, 2025 at 8:52 AM
    DBA0010
    DBA0010 [OP] Member
    David
    Only while moving at a steady speed
  7. Aug 27, 2025 at 9:05 AM
    pod74
    pod74 Active Member
    Carrier bearing possibly? That noise sounds similar to other videos I've seen of failing carrier bearings.
    I had to replace mine recently. It was making quite a bit more noise than what I hear in your video, but mine was in terrible shape.
  8. Aug 27, 2025 at 9:46 AM
    SWPA Tacoma
    SWPA Tacoma Well-Known Member
    Stevo
    2006 White Tacoma DCLB
    Divorce worked for me. Nice and quiet here now :)
    Steves104x4, JohnDoeFasho and Jimmyh like this.
  9. Aug 28, 2025 at 6:11 AM
    DBA0010
    DBA0010 [OP] Member
    David
    I've got a Regular cab which I believe has a single piece driveshaft and no carrier bearing.
    Jimmyh likes this.
  10. Aug 28, 2025 at 11:48 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Probably universal joint(s).
