help in diagnostics
Discussion in 'Technical Chat' started by grantfire319, Apr 18, 2009.
  1. Apr 18, 2009 at 7:09 PM
    grantfire319
    grantfire319 [OP] Well-Known Member
    KENTUCKY
    05 DOUBLE CAB TRD SPORT 4.OL
    Secondary Air Filter removal. More to come hopefully.
    Hey guys, need your analysis here:
    Rotated my tires at work about a month ago, (yes we torqued them to the specs, and in a star patteren). This was the first time I rotated them since I have had the truck. Anyway, when I go to a hard stop, or have to make a sudden stop, my truck pulls in one direction. I can't remember which direction. You can only notice it on hard stops. Also, I seem to have a small vibration in my steering wheel when I get to 60+MPH. Feels like I am driving on a low tire, but there fine. So do you think I have or need:
    1-Brakes
    2-Alignment and or balance
    3-Out of round tire
    4-Loose lug nuts
    5-Caliper or pad dragging
    I got the truck at 56,000. It has 76,000 on it now. I don't know when or if the brakes have been done. If not, I can do them, no biggie. Just don't want to go through the hassle of taking all that crap loose and finding that there good.
    Thanks
  2. Apr 18, 2009 at 7:13 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    im not saying this is the problem, on my flatbed when the truck starts pulling to one side its usually the brakes or rotors depending. if you can pin-point it start cheap then go up
  3. Apr 18, 2009 at 7:16 PM
    grantfire319
    KENTUCKY
    yeah thats what I'm thinking. Probably the original rotors on there. Anyobody else?
  4. Apr 18, 2009 at 7:16 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    It more than likely is a problem with your brake system. Probably warped rotors.
    I'd suggest to flush your fluid, then go from there. Since a fluid change is the cheapest.
  5. Apr 18, 2009 at 7:58 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    My 98 did the same thing, pulled to the right. I had a bad rotor that I had to replace. Consequently it was on the right side. The truck didn't pull until after I replaced the rotor.
  6. Apr 18, 2009 at 8:04 PM
    itsmyturn
    itsmyturn Well-Known Member
    Victorville, CA
    08 dbl cab TRD sport
    afe Pro-Dry S dropin, Readylift leveling kit, TRD skid plate, Alpine CDA-9887, 6K D2S HID
    could be a warped rotor or a bad brake line. quite possibly one caliper in the front may be recieving more pressure than the other.
  7. Apr 18, 2009 at 8:06 PM
    grantfire319
    KENTUCKY
    Thanks guys, looks like have some brake work to do next weekend.
